RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
8ight starter box help
Old 07-25-2008 | 04:03 PM
Default 8ight starter box help
i just got the O.S. V-Spec and i wanna break it in, but the 8ight box can't turn the motor over because of how tight the pinch is. Think heating up the head with a heat gun will help loosen the pinch a little bit?
Old 07-25-2008 | 04:24 PM
K_B's Avatar
K_B
Default RE: 8ight starter box help
Definitely heat it up - to at least 160 degrees. The heat causes the case and the sleeve to expand, loosening the pinch. It makes it easier to start and less stress on the conrod.
Old 07-25-2008 | 04:48 PM
well, turns out all i have at the moment is a hair-dryer, my buddy has my heat gun and i can't get it until next week.
Old 07-25-2008 | 04:59 PM
INTEGRA's Avatar
ORIGINAL: sfar785
careful with the losi box and stalling out the motor's.....i forsee bad things happening if u dont get thet heat gun....a hairdryer will work.....but not as well as a real heat gun will.....and make sure to set-up the box to the chassy before installing the motor....this will help in the long run to make sure the wheel isnt touching the chassy....what kind of battery's are u using ? i suggest using a BIG 12V like a car battery for the first couple times....rewiring the box with 12g deans and soldering all the connections will also help.
Old 07-25-2008 | 05:11 PM
can i get a better motor for that box? as far as battery, i'm using one i got from my LHS. But i have the TFT chassis in my 8ight, so i don't need to dremel the chassis for the wheel.
Old 07-25-2008 | 05:52 PM
I think Integy Lathe motors work well, but I don't know for fact. And definitely heat it up to at least 160.....Your connecting rod will thank you for it.
Old 07-25-2008 | 07:45 PM
INTEGRA's Avatar
Integy 55's.....been workin like a Charm for a couple weeks now.
Old 07-25-2008 | 08:13 PM
sparko's Avatar
Loosen your glow plug a little bit and she should turn right over. I had the same issue with my .18 CV-R and after I loosened the plug she turned right over on the box.
Old 07-26-2008 | 12:10 AM
mabuecker's Avatar
My Feedback: (8)
man Im gonna use my gel cell in my losi box for a 2 day race this weekend ... I got back up motors and think I'm prepared ... if it breaks down I'm calling losi for a refund ... man INTEGRA your box is nice ...
Old 07-26-2008 | 12:46 AM
ORIGINAL: sparko
tried it, didn't work. I dropped the 8ight off at my buddies house, he's gonna break in my engine and everything, then we're gonna hook my box up like Integra's
Old 07-26-2008 | 09:05 AM
Are you using a 12v gell cell??? My 8ight box has no trouble turning over any engine, like INTEGRA said re-wiring it and soldering the connections will help a lot.
Old 07-26-2008 | 12:24 PM
yeah, i use a 12v gell cell, im' gonna need a parts list of what i'll need for the box, anyone else wanna help me with that [&:]
Old 07-26-2008 | 03:42 PM
INTEGRA's Avatar
ORIGINAL: sfar785
couple feet of Deans Wet noodle...red and black
pair of Integy 55's
pair of new Unpressed Pinion's pt# LOSA99403
Bit+tap for a 3mm set screw
mount the pinion's.....wire it up...solder everything....and ur good to go.
