Jammin X1
on the rtr you'll need better servos and aluminum chassis brace also you'll want to put diff oil in the diffs i run 5(F),7(C),2(R) this will make the car handle better other than that you should be ok for a while
ORIGINAL: spencer321
what do u mean by 5(f) 7(C),2(R)
5000 Front
7000 center
2000 in the rear diff.
My setup is pretty close to that, i run 5, 7, 1 on mine...
