which steering servo
I'm going to be getting about $80-$85 soon, and I was just wondering whats the best steering servo in that price range for my 1/8 Hyper 7 buggy? Also, what are some good specs in looking at for a steering servo and also a throttle servo. As of right now I have a hitec hs645. It has about 130 oz tq but it has a speed of .24 I want a new steering servo and I'm thinking of putting that hs645 in as my throttle.
GA
The 645 is SLOW!!!!!!!!!!!!! Try a AE or Ace same thing just different stickers.
http://www.amainhobbies.com/product_...oducts_id/5733
This one is cheaper but not quite as much torque and if all you do is bash will be OK
http://www.amainhobbies.com/product_...oducts_id/5994
Or here is the same thing but with an AE label
http://www3.towerhobbies.com/cgi-bin...?&I=LXTCX8&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXTCX9&P=0
I like the second one alot. In my price range too. Its almost twice as fast as the servo I have now. I bash and drive at a local track. Maybe get into some local races in the future. That servo seems to fit my needs quite well. Thanks 46u!
GA
Get the 1313 for now and when you can afford it get the 1015 use it for the steering then put the 1313 for your throttle and brake. One question what radio are you running and does it have end point adjustment?
ORIGINAL: 46u
GA
I am guessing you do not have end point adjustments so you do not what to run a digital servo like I posted. End point even makes analog servos last longer but is mandatory for digital. Try to find something around 170 to 200oz torque with a speed of .13 or better.
Remember, use a 5-cell NiMh pack for your on-board electrics to get the advertised speed and torque of the servos. If you're using 4 AA alkaline cells at 4.8V, you'll suffer on torque and response time.
GA
ORIGINAL: cobra26
GA
ORIGINAL: apereira
Get the Hitec Titanium gear, 300+ oz. and it is fast.
ORIGINAL: ace9213
What exactly are end point adjusments?
. Servo's in cars like 1/8 scale buggies and truggies work under a lot of load, because of the rough offroading, that's why you can strip/burn weak servo's fast in such cars. In some cars you'll only need for instance 50 degrees of rotating capacity. With End Point Asjustment you can set the max rotation of the servo to a specific percent. If you set the EPA in 50% it will turn 50% less than normal.You need this (EPA) when the car doesn't need the full amount of turn capacity, cuz when you have too much turning capacity, the servo will work under a lot of load and will go to servo heaven (or hell for that matter)
ORIGINAL: ace9213
In that case, yes, I I do have end point adjustments. Is it safe for me to run digital if I get a 5-cell NiMh pack then?
It's not the steering trim if that's what you mean. My radio has a little knob on it where it controles how much the servo is allowed to turn.
ORIGINAL: ace9213
GA
As long as you have an adjustment where you can limit the end points in both directions running a digital servo will be fine but just make sure about your end point adjustment or it can be a costly mistake.
ORIGINAL: 46u
GA
ORIGINAL: ace9213
If I can't will it burn the servo out?
ORIGINAL: 46u
TX
46u, I am interested in a servo just like that as well, and I like the look of those ace ones, but as for a radio system, do you recommend the Dx2?
GA
ORIGINAL: Frozenshade
TX
ORIGINAL: 46u
Racing or bashing? The DX3.0 would be better. I have a Nomadio React and love the radio but getting extra receivers and support is terrible. [:@]
GA
Bit of both. Some racing, some bashing. The DX3 looks nice, but its expensive. My hobby shop sells the DX2 for $140. Not sure about the DX3 price at my local shop, but I see online that its around $250. Is it really worth an extra hundred bucks?
ORIGINAL: 46u
