RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Converting to non-pull start
Old 10-27-2008 | 05:27 PM
Default Converting to non-pull start
I have a Mach .28 on my hyper which has a pull start which broke a while back. since then I've been using a starter box which is probably the best investment I've made in this hobby.
I was wondering what parts I would have to buy to convert it to non-pull start. I was wondering if this would do the trick.
http://cgi.ebay.co.uk/OFNA-53089-HYP...3286.m63.l1177
Old 10-27-2008 | 05:28 PM
adam-69's Avatar
Default RE: Converting to non-pull start
yip. just bolt that on and your ready to rock.
Old 10-27-2008 | 05:39 PM
awesum cheers mate...at the moment its still running with a pullstart cover on...which adds drag and gets in the way of the manifold.
Old 10-27-2008 | 06:26 PM
46u's Avatar
46u
Are you sure you will not have to either replace the crank or cut the crank you have?
Old 10-27-2008 | 07:04 PM
adam-69's Avatar
nah i just cracked my mach .28 open. the pullstart has an insert that comes out of the centre of the crank leaving a hollow pin with the con rod on it, but nothing sits proud of the con rod.
Good thinking though 46u.
Old 10-27-2008 | 07:56 PM
46u's Avatar
46u
Some engines have a different crank for pull start version plain back is why I asked. Most times if it does you can cut the crank. But glade in this case he will not need to do anything.
Old 10-27-2008 | 08:27 PM
How much of a negative effect do pull-starts actually have on performance? Is it a noticeable amount, or so minor that it is only worth it for serious racers?
Old 10-27-2008 | 08:38 PM
I have a hyper tq rtr that is a pull start and one day i was a track in slough and they saw i was having trouble starting my car and a shop called hc models made me a costom starter box to fit my car and it still has the pull start on it. What im trying to say is maybe it might be cheaper just to get a starter box
Old 10-27-2008 | 08:43 PM
46u's Avatar
46u
ORIGINAL: Adam Reavey
You most not have read his post as he says he has and uses a starter box![X(] The problem with keeping the pull starter is you have drag from the one way bearing as well as a bigger chance of an air leak and fuel all ways leaking out the back.
