RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
CRANKSHAFT PROBLEM
Old 12-13-2008 | 07:15 AM
Default CRANKSHAFT PROBLEM
Hi I have a Novarossi 21-5kt engine when I am tightening the flywheel up tight on the collet the crank seems to be binding on my rear bearing not letting it spin freely any suggestions would be great cheers!
Old 12-13-2008 | 10:23 AM
Default RE: CRANKSHAFT PROBLEM
Is the collet going too far into the flywheel allowing the flywheel to hit the engine block. I had an rb engine with that problem & put 1 shim behind the collet (between collet & bearing) & it is now fixed.
Old 12-13-2008 | 06:08 PM
No because I have tried it with the internals out and when I tighten the flywheel I can see the crank pull in to tight on the rear bearing
Old 12-13-2008 | 08:39 PM
Just put a shim behind the collet.
Old 12-13-2008 | 09:25 PM
46u's Avatar
46u
Did you by chance just replace the bearings? If so you might not have the inner bearing seated all the way. Had this happen to me.
Old 12-14-2008 | 07:02 AM
I have just bought the crankcase off ebay bearings installed whats the best way of fix if I have to take the bearing out whats the best method to install it again beacause I have had big problems installing novarossi bearing thats why I had to replace the crankcase this is my second
