please,please help
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
RE: please,please help
Not trying to diss you man, but when you say you've set the epa's.....are you talking about the little switch next to the sterring wheel on your transmitter, or are you talking about going into the throttle servo settings on the menu tree in your transmitter and setting the max throw limit?
Get the Losi addendum to the manual on setting it up [link=http://www.losi.com/ProdInfo/Files/LOS_Throttle_Addendum.pdf]here[/link]
Its a common issue that is only cured by careful setup.
