RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
4PK owners
Old 12-19-2008, 11:30 AM
Osirisf16
Osirisf16's Avatar
Default 4PK owners
To all 4PK owners, i want to ask something. I ordered my 4PK and i hope have it this January. So, is there something that i must know before and while using the 4PK? I want to tell me everything.
Thanks [8D]
Old 12-19-2008, 03:31 PM
K_B
K_B's Avatar
Default RE: 4PK owners
RTFM...
Old 12-19-2008, 04:26 PM
losiben888
Yea what he said!
Old 12-20-2008, 12:47 AM
Osirisf16
Osirisf16's Avatar
And what that means?
Old 12-20-2008, 04:23 AM
SManMTB
SManMTB's Avatar
Download the manual and fscking read it.
Old 12-20-2008, 04:37 AM
Osirisf16
Osirisf16's Avatar
No, i don't mean those things. I read the manual already. Just need to know if there is something that the manual doesn't say and i must know. If there is a problem with something or like that. Just wanna know what i must do and what mustn't do. Can you feel me dude? [8D] Experience*
Old 12-20-2008, 09:44 AM
INTEGRA
INTEGRA's Avatar
DONT RUN hrs on Non digital servo's....ive seen it ALL too many times with my buddy's who dont have A CLUE about the 300$ radio they rock....and ive caught a few of them in HRS when they should NOT be.
Old 12-20-2008, 10:32 AM
Osirisf16
Osirisf16's Avatar
Yeah, i read that somewhere. And if you are using normal servos you must set your radio to PCM (i think), right?
Old 12-20-2008, 01:50 PM
SManMTB
SManMTB's Avatar
FASST receivers have a tendency to loose lock when they get hot.
Futaba now finally states that they work up to 50C (122F).
Get a 3PKS + Spektrum instead.
Old 12-20-2008, 01:53 PM
SManMTB
SManMTB's Avatar
ORIGINAL: Osirisf16
PPM
Old 12-20-2008, 02:14 PM
INTEGRA
INTEGRA's Avatar
ORIGINAL: SManMTB
where is this ?
Old 12-20-2008, 04:46 PM
SManMTB
SManMTB's Avatar
In the 10C manual.
Old 12-20-2008, 06:20 PM
K_B
K_B's Avatar
ORIGINAL: INTEGRA
ORIGINAL: Osirisf16
I don't suppose you read in the manual maybe?
I remember Renauld Savoya's buggy at the Euros had holes drilled all over his radio box and his body because of heat issues with the receiver. I figured they had addressed that problem by now.
Old 12-20-2008, 06:24 PM
SManMTB
SManMTB's Avatar
No, it's Futaba. Nothing is ever wrong with Futaba. Don't expect miracles.
Old 12-20-2008, 06:26 PM
INTEGRA
INTEGRA's Avatar
ORIGINAL: SManMTB
it appears there's more to the story then just this.......and keep in mind this is for a 14 channel Air receiver...not a 3 surface receiver.
Right from the 10C manual
"Product Advisory — R6014FS Receiver
Whereas many previous receivers offered a signal output of 3.0 Volts, the latest generation of ICs has been designed to operate at lower voltages in order to increase their operational speeds. The R6014FS receiver utilizes such an IC and, as such, the nominal signal output voltage of the R6014FS receiver is 2.7 Volts.
While this variance in the output voltage will not affect most equipment in use today, it has been brought to our attention that some manufacturers’ products are not capable of operation with the lower signal voltage. That is, they will not operate below 3.0 Volts. Some examples of what we have had reported thus far include
sequencers, cut-off valves, older servo designs and some recent non-Futaba digital servos.
they might not appear to initially. One such device functions perfectly on the ground and during a range check, yet when the operational temperature reaches 50°C (122°F), the device actually requires 2.8 Volts in order to function properly. As such, the servos will cease to operate properly.
Many manufacturers are updating or refining their products to ensure compatibility with the lower operational voltages. If you have any questions about the operation of such peripheral items we strongly suggest that you contact the manufacturer directly.
If you have already purchased items which can not operate below 3.0 Volts, we suggest that you either replace the item with an updated version or utilize a device to increase the voltage accordingly. There are a number of readily available devices that may be used to increase the voltage such as ElectroDynamics products, Smart-Fly’s Power Expander and Powersystem, etc.
Old 12-26-2008, 02:33 PM
JLRevo
JLRevo's Avatar
No, nothing special. Just get it charge and play with all the menus. Get them setup the way you want. There a "switch function" in the menus that let you assign a "idle up" , "ABS" and other funstion to mutiple switches on the controller for direct access. The Idle up function is great. Hands down you'll be very happy with the purchase. I'm gald I had this since they came out. The price is scary but you get every dime out of it. And I've never seen a 4pk sold for under $340 so you'll get some of your money back when you decide to every get rid of it.
4pk in the back hiding behind the wing. She's camera shy.
Old 12-26-2008, 08:51 PM
ket2175
Hi all my 4pk batt pack used up quite fast. Anyone have the same problem as me ?
Pls advice. Many thanks.
Old 01-06-2009, 06:43 PM
gtr
gtr's Avatar
Anyone know the R604 receiver DSC port can use for battery port ?
