new picco 9.5 rtr
new picco 9.5 rtr
just picked one up and it runs handles excellent compared to the revo, its freaking amazingly fast and can turn at speed without rolling, lol. and quick mods i can do to increase performance? is the stock resonator set for max performance or are there better pipes out there for the .21?
RE: new picco 9.5 rtr
well i found out the hard way i need a beefed up steering servo the hard way. first time it didnt land right and cartwheeled it stripped the gears inside the steering servo, and suggestions on servos? futaba? and model numbers? thanks
hanks for the advice, i was looking at the futaba because of low price, hitec servos are pricey but i guess you get what you pay for
ORIGINAL: tjjolliff
HITEC HS-7965MG V2 DIGITAL HIGH SPEED SERVO!!!! what i was thinking of getting, sound like a good choice??
GA
I recommend a servo with at least 175oz torque and a speed of .13 or faster. A good servo makes a BIG difference in handling.
I run the AC which is the same thing as a ACE 1313 for the brake throttle and the 1015 for steering.
http://www3.towerhobbies.com/cgi-bin...&I=LXTCX8&P=ML
I run these in my Hyper 8.5, my race Savage and will be running the 1313 for a throttle brake in my new HPI Baja B5 SS. The B5 is a 1/5 scale and comes with a giant steering servo.
ORIGINAL: 46u
GA
Did you read the discretion in the links I posted?
this is on the DS1313
FEATURES: Metal gears Coreless motor offers smooth operation and fster response time Aluminum heat sink dissipates heat build-up for fade free performance Water and dust resistant
INCLUDES: Associated XP Digital DS1313 Servo with JR type connector, 1.7" (44mm) long double servo arm Mounting hardware
REQUIRES: Installing in vehicle and connecting to receiver
SPECS: Dimensions: 1.6 x 0.81 x 1.5" (41.8 x 20.6 x 39.6mm) Weight: 2.32oz (66g) Torque: 173.6 oz-in (12.5 kg-cm) @6V Transit Time: 0.13 sec/60°
