RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
xtm xt2
Old 02-23-2009 | 12:55 AM
boony66's Avatar
Default xtm xt2
does an1 know the factory needle settings
thanks jake
Old 02-23-2009 | 01:38 AM
IloveMYxt2's Avatar
Default RE: xtm xt2
I believe its 3 turns out for both HSN and LSN. And I am assuming you have the 24.7 engine.
Old 02-23-2009 | 09:27 PM
rclynx's Avatar
Default RE: xtm xt2
HSN is 3 full turns out
LSN is hold the throttle open all the way, bottom out the LSN and back it out 3 full turns.....................throttle must be held at full open doing this adjustment [8D]
Those are factory break in settings...........you will have to do some adjusting after set up [:-]
Old 07-05-2009 | 11:10 PM
Default RE: xtm xt2
wrong, wrong,wrong.... the HSN is turn it in tilits all the way, then turn it anticlockwise 3.5 turns and the LSN is pull the barrel out with your finger, turn the needle till its all the way in and then turn it back 3 turns (whilst pulling the barrel out)</p>
