RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Calling all Picco Guru's
Old 04-08-2009 | 03:44 AM
Default Calling all Picco Guru's
Could anyone tell me the difference between the Picco P7R-EVO2 & Picco P7-EVO3? I want to buy one of these for my Hyper 8.5 buggy?
Old 04-09-2009 | 12:23 AM
Default RE: Calling all Picco Guru's
Anyone?
Old 04-09-2009 | 12:31 AM
I'm sure Supertib and/or Integra will chime in shortly.
Be patient.
Scott
Old 04-09-2009 | 07:52 PM
hi im a picco guy. the diiferences are the evo 3 has a lil bit different porting in
the block to get that better fuell milliage that the 2 lacked and the crank isnt as crazy so over all the 3 is smoother but still
puts down the power. If i were u look at what your goin for and what kinda track ur racing on. if u race on smaller tracks
then go with the 2 but if u run on big tracks go with the 3.
Old 04-09-2009 | 11:05 PM
INTEGRA's Avatar
well said crazy 8t you hit the nail on the head....basically its all timing #'s that is the difference....o and the non fall apart head..(evo 2 heads like to rattle apart after a couple gallons)...so i would go with the JPX version for the price and the head that wont start rattling after a gallon or so.
Old 04-10-2009 | 08:14 AM
Thanks Intergra. Ya idk why the heads do that but every picco head iv ever had has done that so i just take the head off after break in
and put an O.S Rocket racing head on them.
Old 04-10-2009 | 09:18 AM
supertib's Avatar
EVO 2 and EVO 3 are identical... cranks are the same, block porting is the same, sleeve porting is the same...the only difference is the EVO3 has a shim under the sleeve to slightly raise port timing....
Old 04-10-2009 | 09:31 AM
INTEGRA's Avatar
ORIGINAL: crazy 8t
i tried the Fatt Head from Trinity...HOLY CRAP it weigh's a Tonne...ill stick to my stock JPX head thx. [sm=lol.gif]
Old 04-10-2009 | 06:00 PM
anyone else make a head for the picco's? I wouldnt mind having one either, but not crazy about crazy nut, or the trinity.
Old 04-10-2009 | 07:40 PM
INTEGRA's Avatar
ORIGINAL: NORCALLUMP
JPX version ?
Old 04-11-2009 | 07:09 AM
Is it a must to seal the carb?
Old 04-11-2009 | 08:46 AM
INTEGRA's Avatar
ORIGINAL: joydude630
IMO yes....strange things can happen if you don't.....i used to play devil's advocate with which carb i would seal...but no more...i just seal them ALL and be done with it.
Old 04-11-2009 | 09:53 AM
ORIGINAL: INTEGRA
+1 I seal every engine I have.....eliminates headaches.
Old 04-11-2009 | 12:53 PM
Can I use this to seal the engine? http://www.amainhobbies.com/product_...ducts_id/25728
Old 04-11-2009 | 04:02 PM
INTEGRA's Avatar
yuppers
