RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   hyper 8.5 questions, need help (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7206047-hyper-8-5-questions-need-help.html)
rezac 03-13-2008 01:59 PM
RE: hyper 8.5 questions, need help
What degree castor blocks does the pro kit come with from the factory?
Furadi 03-13-2008 02:42 PM
ORIGINAL: rezac
22 I think, thats what the Hyper 8 came with.
Furadi 03-13-2008 02:43 PM
ORIGINAL: Dokioto
Will these caster blocks also fit the Ofna Ultra series (LX1)?
Probably not, but you should be able to find a way to adjust caster.
mrbonk 03-13-2008 03:25 PM
ORIGINAL: Furadi
Have you tried the 20's or 18's? I felt there was to much understeer in my Hyper so I switched to 18's. It went form turning wide, to spinning out if I cut the wheel to hard. Its a HUGE difference. Just make sure you use red loctite on those bottom knuckle bushing screws.
Not yet. I've read a bunch of stuff about suspension alignments recently, so it's on my list of things to try though.
Furadi 03-13-2008 06:55 PM
ORIGINAL: mrbonk
ORIGINAL: Furadi
Trust me, try it first, you'll be blown away by the improvement.
rezac 03-13-2008 07:31 PM
I will have to invest in some also then. I just dont want to get it dirty lol, it looks so good right now lol. I am going to paint eth body within a couple of days here..
Furadi 03-13-2008 07:35 PM
ORIGINAL: rezac
What are you running? Hyper 8's come with optional caster blocks..
rezac 03-14-2008 02:02 AM
I have the 8.5 pro. No idea which caster blocks I have installed. I don't know how to tell.. I didnt know it came with extra ones, maybe I did, I do have some extra parts but now I will have to look for them again lol.
Furadi 03-14-2008 07:53 AM
ORIGINAL: rezac
Probably the 22's. You have to take the wheel off. Then you can see the number on the side of the block.
rezac 03-14-2008 03:13 PM
oh ok, I will check it out. Speaking of wheels, I am disappointed, the wheel nuts say hobao on them, well 3 out of 4 do, kinda makes me mad lol..
rezac 03-16-2008 05:25 PM
You are right Furadi, mine came with 22's on it and came with the 20's and 18's as the optional ones. Which ones do you suggest more? 20 or 18?
46u 03-16-2008 08:18 PM
All you have to do is look on the blocks and it is written on them! :eek:
Furadi 03-16-2008 08:45 PM
ORIGINAL: rezac
Try them both! I went straight to the 18's though.
