Go Back  RCU Forums > RC Boats > RC Airboats
 Airboat - first timer problem >
RC Airboats Discuss R/C Airboats here!
Old 10-10-2004 | 11:47 PM
Default Airboat - first timer problem
hi guys
I just got into airboats and made my first airboat from my airplane spares.
The first attemp was great and managed to get the boat floating and moving around fine. Here're the details
a) dimension: 17" (length) x 11" (width) and 2" (height), tapered 45 degrees on front
b) engine: ASP .21 with 8x6 prop
c) the cg is at about 30% from the back
The problem is when I power up to about 40% throttle, the front of boat starts to lift up and down, bouncing of the surface of water as it is speeding. When I further pushed the throttle to about 70%, it lifts up further and flips!!
I tried moving the CG to about 50% of the boat (horizontal) by relocating the engine. No improvement!
Hope to get some help from the experts!!
Thanks!
Old 10-11-2004 | 06:31 AM
Selph-Inflicted's Avatar
Default RE: Airboat - first timer problem
You need to adjust your thrust angle on your prop.
Shim the front of the motor with a washer under the front of the motor. This will give you more down force on the bow.
There is a post at Rc ABW on this. I'll find it and send you the link when I get home from work.
Old 10-11-2004 | 11:02 PM
thanks for the tips! will try it out this weekend.... can't wait
