handling problems light steering
Hi Guys i had an asp 61 on my boat it was great till it died
so bought an os 61 very powerful that good ripped the engine mount off the hull
so tried a few things but too heavy ended up fitting to strips of wood
for the engine mount to sit on with aluminium warped around to hold it on now this increased the engine height by 1.5 cm had tons of problems so now got the engine down to the original height of the old engine but the handling is really bad very light you just touch the control it spins around is the engine still to high i got a film of it in the water it just wants to go around in circles all the time does not want to go straight
its a heavy hull i have but still go,s not that bad its a brand new engine just a few runs with it what am i doing wrong I look forward to your reply
here it is running
http://www.youtube.com/watch?v=As34Gr_LOPM
here it is running
FL
I don't think it would be a weight or center of gravity issue. Normally when something won't go straight it's because it's going faster than what the hull can handle, it's "out of control". The only thing I can think of for you to try is to add a fin or two to the bottom. I think that will make it go straight when you want it to, even if my assumption of the problem is wrong. Give it a try.
did the engine mount get put back on just a little askew? Maybe the angle of the engine is just a few degrees off of what it used to be.
Hi I think you are right engine mite not be straight so taken it off as soon as i get time remount it try get it straight i mite even make up a new mount do away with the engine mount have it mounted onto a new stand but i try to re mount it for the moment
as im having problems with my other boat got to try sort that out too lol soo much to do soo little time got a plane learning how to fly funny thing is every one puts on a crash helmet and runs away as soon as i take off lol must have seen my air boat lol
