Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
Bro rc Surfer Custom Boards
RC Boats General Discussion Discuss general rc boating topics here.
View Poll Results: Would you like to see a Bro******** e-book published
Yes - that would be great !
17
73.91%
Not particularly
6
26.09%
Voters: 23. You may not vote on this poll
Old 04-19-2014, 12:03 PM
  #726
YPC
YPC's Avatar
Stopped off at Table View ( Blouberg) for a quickie - on route up the West Coast - wasted a few Amps - conditions were better for some Kite-boarding air renditions - rather than to much surfing ........very impressed with how the board actually stayed 'on the water' battling the windy conditions.....for most of the time...
Happy Easter Sunday !
https://www.youtube.com/watch?v=F33VGtkVgjM
Old 04-20-2014, 12:43 AM
  #727
YPC
YPC's Avatar
what's SUP Bro !
ID:	1988350   Click image for larger version
ID:	1988351   Click image for larger version
ID:	1988352   Click image for larger version
ID:	1988353   Click image for larger version
ID:	1988354   Click image for larger version
ID:	1988355   Click image for larger version
ID:	1988356   Click image for larger version
ID:	1988358   Click image for larger version
Old 04-21-2014, 05:49 AM
  #728
YPC
YPC's Avatar
Running a Leopard 3650 / 2450 kv motor - 4s Lipo / 5000 mAh - 120A ESC - all metal gear servo - 2.4 gig HK2 TX/RX
When running a solid shaft - special care is to be taken to ensure
that the shaft is 100% lined up ....
Servo fitted into a servo tray for a secure / rigid fit.
Battery platform positioned across the POD..black Velcro to attach battery
Front end of the stuffing tube left to float, to accommodate any small vibration / misalignment.
Stuffing tube end only extends into the first well of the pod, so that water which
travels up the stuffing tube is kept away from the motor bearing.
ID:	1988633   Click image for larger version
ID:	1988634   Click image for larger version
ID:	1988635   Click image for larger version
ID:	1988636   Click image for larger version
ID:	1988637   Click image for larger version
ID:	1988638   Click image for larger version
ID:	1988639   Click image for larger version
ID:	1988641   Click image for larger version
Old 04-22-2014, 12:24 AM
  #729
YPC
YPC's Avatar
Default RIGHT Bro !
Been wondering if the SUP Bro would self right efficiently, having the added weight of the paddle as well as the now sightly wider board.
Still needing to add a few finishes - wanted to get it tested soonest- to set my mind at ease...
Weighing in at 2.3 kg's ( 5 lbs) RTS - it PASSED the Jacuzzi test...
https://www.youtube.com/watch?v=QCyWgFWUwDk
Old 04-22-2014, 08:15 AM
  #730
YPC
YPC's Avatar
Default Water Pick Up
4mm brass tubes bent smoothly through 90 degees
Tubes mounted against side walls of housing for extra strength and to enable the silicon tubes to be
positioned out of the way - not to get damaged when changing out batteries.
Tubes epoxied into position - ensuring a solid mount - well sealed all round.
Brass tube to extend by 10 mm's - a pool of resin is flowed around the pro-
truding brass tube to add to the strength and seal.
Once the resin kicks.. the tape is removed to reveal a neat seal to be sanded.
ID:	1988951   Click image for larger version
ID:	1988952   Click image for larger version
ID:	1988953   Click image for larger version
ID:	1988954   Click image for larger version
ID:	1988955   Click image for larger version
ID:	1988956   Click image for larger version
ID:	1988957   Click image for larger version
ID:	1988959   Click image for larger version
ID:	1988960   Click image for larger version
ID:	1988961   Click image for larger version
ID:	1988962   Click image for larger version
ID:	1988963   Click image for larger version
ID:	1988964   Click image for larger version
ID:	1988965   Click image for larger version
Old 04-23-2014, 01:25 AM
  #731
YPC
YPC's Avatar
Default Rudder Push rod
Like the water cooling tubes - the rudder push rod is mounted against the housing wall for strength
and kept well out of the way of the battery pack area.
ID:	1989191   Click image for larger version
ID:	1989192   Click image for larger version
ID:	1989193   Click image for larger version
ID:	1989194   Click image for larger version
ID:	1989195   Click image for larger version
ID:	1989196   Click image for larger version
ID:	1989197   Click image for larger version
ID:	1989199   Click image for larger version
ID:	1989200   Click image for larger version
ID:	1989201   Click image for larger version
ID:	1989202   Click image for larger version
ID:	1989203   Click image for larger version
Old 04-23-2014, 06:24 AM
  #732
YPC
YPC's Avatar
Default Bro Bond !
Last bonding process..phew...permanently securing Bro to the Hatch cover.
A slow curing epoxy is best used to ensure a well saturated bond between Bro's
foot pads and the hatch cover.
ID:	1989238   Click image for larger version
ID:	1989239   Click image for larger version
ID:	1989240   Click image for larger version
ID:	1989242   Click image for larger version
ID:	1989243   Click image for larger version
ID:	1989244   Click image for larger version
ID:	1989245   Click image for larger version
ID:	1989247   Click image for larger version
Old 04-24-2014, 08:58 AM
  #733
YPC
YPC's Avatar
I reckon many would / could debate their personal 'preference' between a Production board and a Custom board......horses for courses.....BUT - you cant beat the authentic look and feel of a glass over foam, high gloss custom rc surf board....definitely at the next level ....so well worth the effort !.....
https://www.youtube.com/watch?v=4qUmQ8dBO78
Old 04-25-2014, 03:42 AM
  #734
YPC
YPC's Avatar
Default SUP Bro rc Surfer DONE !
Just on 1 month of tinkering, between so many other things, including a few great surf session - the SUP Bro build is RTS ( Ready To Surf) ......
Flat water tested this morning....very happy with the performance...... and hoping for a surf session this Arvi !
https://www.youtube.com/watch?v=Ako_OxYFV-8
Old 04-26-2014, 10:44 PM
  #735
YPC
YPC's Avatar
FIRE !!!!!!!.......
Fortunately for me ..... I was at home - my garage alarm sounded and drew my attention to the workshop...for those of us that think it will never happen.....here is evidence that it sure does..... !!!!!!"....fortunately it was contained to my charging area.
I had checked on the battery charging about 15 minutes prior - all was good ...
ID:	1990291   Click image for larger version
ID:	1990292   Click image for larger version
ID:	1990293   Click image for larger version
Old 04-27-2014, 11:48 AM
  #736
YPC
YPC's Avatar
Finally ....in the surf .....not the best of surf ...but showing good promise for the coming Winter swell ...
Running 3s packs ....4s's are fried !.....
https://www.youtube.com/watch?v=aI5hZJUFFBg
Old 04-28-2014, 10:10 AM
  #737
YPC
YPC's Avatar
https://www.youtube.com/watch?v=pezxIF0wGDs
Old 04-28-2014, 01:09 PM
  #738
YPC
YPC's Avatar
SUP Bro got his board back.....
https://www.youtube.com/watch?v=1OEnupeDhyg
Old 04-29-2014, 01:29 PM
  #739
YPC
YPC's Avatar
Had 'another ' awesome session with SUP Bro rc Surfer to-day. The new board is certainly playing out its design expectations.......as I become more accustomed to it......riding out the hollows very smoothly .... pulling quick / responsive lip turns.....nice tail slides, due to the wide square tail.....currently powered by 3s lipo's (lost my 4s's in the fire)...looking forward to 'sea - ing' it rip when powered by the 4s's.....
Love the video sound track - Africa - by Toto
https://www.youtube.com/watch?v=sBff71el3ok Definitely achieved what we set out to do .... Trust that sharing the info encouraged you to give it a go - or - added some value to a build you may undertake....always feel free to share your builds - experiences - pics - video's...and to ask the questions never asked !.....
TEST REVIEW
Edited the previous video's to highlight and demonstrate the SUP Bro boards noticeable features - looking forward to getting to know them better and enjoy them in the coming Winter swell .....
https://www.youtube.com/watch?v=7DeN6YRyJ3g
Old 04-30-2014, 12:17 AM
  #740
YPC
YPC's Avatar
Hand Me Downs !
Jenson inheriting one of the old Shred'A's.......will set it up as a 2s
Old 04-30-2014, 10:56 PM
  #741
YPC
YPC's Avatar
What are you doing Jenson ?...... making a bate boat conversion hatch cover for my Bro board dad ......
Old 05-01-2014, 09:43 PM
  #742
YPC
YPC's Avatar
Thusday Arvi - the swell keeps delivering and SUP Bro just cant hang around the workshop....,,,,,really enjoying discovering this board...
https://www.youtube.com/watch?v=JviwsncS10s
Old 05-02-2014, 06:56 AM
  #743
YPC
YPC's Avatar
Off for an Arvi Session ...
ID:	1991915   Click image for larger version
ID:	1991916   Click image for larger version
Old 05-02-2014, 11:14 AM
  #744
YPC
YPC's Avatar
The love catalyst for Lisa-Marie Young and myself over the past 20 plus years has certainly been spending many precious moments together - sharing our sports - creating business's - growing our family - Today was no different - Sharing a few amazing moments on the beach together - enjoying something we enjoy - with the one we love - enveloped in Gods creation - just does not get any better - Love You Babe !
still trying to find out which one took my batteries ........
......lol
https://www.youtube.com/watch?v=_lwm-Y9gWis
Old 05-04-2014, 10:27 PM
  #745
YPC
YPC's Avatar
Surf dropped off - weather got cold and windy !...
Simply love the sight and smell of the beach - no matter what the weather - food for the soul - more so - always such a great place to make new friends - cant count the number of wonderful folk we have come to know sharing the
Bro rc Surfer stoke !
As for Lisa-Marie Young braving the cold to film - It must be Love !
https://www.youtube.com/watch?v=KL89QL-ON2o
Old 05-07-2014, 04:50 AM
  #746
YPC
YPC's Avatar
Classic Surf to-day !....
Been limping on only 3 remaining batteries for the past days... since the fire.....that ship from China best 'hurry up'
Had some clasic rc Surfing surf roll into the bay to-day...
Ran two rather puffed 3s's in this session....
https://www.youtube.com/watch?v=69_mj9kW3nk and....one puffed 4s in this session.......
https://www.youtube.com/watch?v=_MyUR1uAyMM
Old 05-07-2014, 01:27 PM
  #747
YPC
YPC's Avatar
One more session - just before Sun down.....because I am Free to...
https://www.youtube.com/watch?v=Cju8CLUP3Eg
Old 05-09-2014, 05:57 AM
  #748
YPC
YPC's Avatar
Epic Friday session !...
Aqua Blue ocean - Off-Shore Breeze - Triple overhead surf- Nickleback sound - one or two little barerls to cap it - Having it all to oneself - Great way to start the weekend !
Cemetery Beach - False Bay - Cape Town
.. https://www.youtube.com/watch?v=rpFPgnaVouw
Old 05-10-2014, 02:45 AM
  #749
YPC
YPC's Avatar
NEXT !...block of foam for a shaping !...
Building another SUP Bro ....this one is bound for France !..we...we !...
ID:	1994021   Click image for larger version
ID:	1994022   Click image for larger version
ID:	1994023   Click image for larger version
ID:	1994024   Click image for larger version
ID:	1994025   Click image for larger version
ID:	1994026   Click image for larger version
ID:	1994027   Click image for larger version
ID:	1994029   Click image for larger version
ID:	1994030   Click image for larger version
ID:	1994031   Click image for larger version
ID:	1994032   Click image for larger version
Old 05-10-2014, 07:41 AM
  #750
YPC
YPC's Avatar
Cant Stop ....Addicted !.
After spending the morning in the workshop shaping a new board... - it was time to hit the surf again.
Tide was fairly low - back line to far out - BUT - managed a few good waves in the reform...
https://www.youtube.com/watch?v=_LmBYZiC7bw
