RC Boats General Discussion Discuss general rc boating topics here.
rc boat problem
Old 07-18-2005 | 09:02 AM
Default rc boat problem
hey guys - i left my rc (electric) boat out in the rain and the controller.
i drained the boat and then dried out the controller.
everything works fine up close but it seems the radio distance is gone.
like a 5 foot range!
what can i do to fix this?
thanks!
Old 07-18-2005 | 11:25 AM
Default RE: rc boat problem
help!
Old 07-18-2005 | 11:53 AM
Umi_Ryuzuki's Avatar
If the boat was "full" of water, there may still be water in the equipment.
Same with the transmitter, if there were puddles of water sitting on or in it.
Open everything up and "really" dry them out.
http://www.rcgroups.com/forums/showthread.php?t=153344
Old 07-18-2005 | 12:01 PM
umi - you are a godsend - i appreciate it.
i will dismantle and alcohol rub the circuits.
get the rust off too. thanks very much bro........
Old 07-18-2005 | 03:56 PM
Even if the water is gone, the residue will still be there and cause problems for you. You need to CLEAN all circuit boards that got wet with alcohol . Scrub them with a brush and wash down with more alcohol until all the residue is gone. Make sure all connectors are clear of moisture espically under/around the crystal. As a final step, after cleaning with alcohol, bake everything as disassembled as possible in the oven at no more than 120 deg for 12 hrs. If all else fails or you are not comfortable doing any of this, send it back to the manufacturer for testing and repair. It usually is not very expensive and gives you a warm and fuzzy that everything is checked out well.
Old 07-19-2005 | 08:54 AM
wow skoda! thanks!
i think i can bake it in the hot sun here for a couple hours?
do i have to take boat apart or just remote?
im thinking just remote correct?
you guys know your stuff.
Old 07-20-2005 | 09:31 AM
ok i took the controller apart and the boat and cleaned with rubbing alcohol.
i blew with canned air.
the distance is farther - range is now 10 feet.
one thing - where the hell is the crystal? what does it look like?
i wanna get this little sukka goin!
thanks!
Old 07-20-2005 | 11:55 AM
Did you take apart the Reciever and the servos in the boat?
Crystals look like small metal cans with two prongs. They have the frequency printed on them, or paper tags listing the frequency.
They look like this
http://www2.towerhobbies.com/cgi-bin...al&FVPROFIL=++
Unless this is more of a "toy" boat in which the frequencies are sometimes hard wired into coils.
Old 07-20-2005 | 11:59 AM
thanks so much man. yeah i took apart the receiever and boat but not the servos.
it is weird. everything mechanically works right but the distance is reduced.
cleaning all the parts made the distance pick up a little maybe need to dry more?
been two weekes since the water logged incident.
this is more of a toy but it doesn have a crystal like that.
Old 07-20-2005 | 06:37 PM
Ron Olson's Avatar
What type of boat is it? If it is something like a Nikko or Radio Shack kind of boat, you won't really see a crystal like one that a regular reciever that is normally used will have. I've used a Mineral Spirits based waterproofer on my sevos and recievers and has brought recievers back from the dead, one that had sat in my basement for 2 weeks.
Old 07-21-2005 | 11:24 AM
its a nikko.
i will try again tonight.
thanks guys!
Old 07-22-2005 | 09:40 AM
the damn thing is not responding from anything over 10 feet.
i cannot figure this out.
the motor and servos run perfectly when the control is up close to the boat.
what is going on?
thanks guys.
Old 07-22-2005 | 12:34 PM
Ron Olson's Avatar
I don't know electronics but this can happen to the best radio systems. It must be that when you switched on the wet reciever you fried some components.
Old 07-22-2005 | 12:38 PM
ORIGINAL: Ron Olson
Hopefully that is not the case.
The coils, the little square metal cans, on the circuit board may still be holding water. It may take a while to really dry out as they are sealed. [&o]
Old 07-22-2005 | 01:29 PM
i thought i may have fried some stuff to but up close that thing runs like a charm.
waddya think i should do?
dry those cans?
i appreciate your help guys.
i really do. if fried - then what?
Old 07-26-2005 | 08:23 PM
Bombers_410's Avatar
well then you need to do this in order from 1 to watever number i end on.
1. click on this - www.offshoreelectrics.com
2. click on the main page.
3. click on electric boats
4. click on whatever boat u think looks cool
5. click add to cart
6. type in where you want to ship to, credit card #, etc.
7. wait for your new fast electric that will blow your nikko out of the water
o and make sure you buy batteries and charger from somewhere too
Old 07-27-2005 | 02:58 PM
ORIGINAL: moosemessier
what is going on?
thanks guys.
I had a similar range problem after submerging my Futaba receiver, turned out a coil was shorted out and severely limited the range, like you described.
Sent it to the manufacturer and got the coil replaced, works fine ever since.
Regards, Jan.
P.S.: I doubt though, if it's worth the trouble with your Nikko boat, inquire about the costs involved before you ship it.
The Offshore tip is good!
Old 07-27-2005 | 08:20 PM
Ron Olson's Avatar
When you buy a Nikko, Radio Shack, NKOK or any other low dollar boat and have problems with them, usually you're outta luck. Most aren't worth the time or cost of repairing them so the get tossed. With the low cost boats coming out today like the Zig-Zag Racer and Reef Racer, it's money better spent because you can get parts for them if needed plus for the same cost you'll get a better and faster one.
Old 07-29-2005 | 05:32 AM
13BT's Avatar
if you want to dry really hard to reach places, pack those components into an airtight tupperware and throw in a few of those silica gel bags with it. They are dessicants and are designed to absorb moisture.
you might be able to get a few for free if you ask at a camera shop
Old 07-29-2005 | 08:37 AM
Regards, Jan.
the range is getting better - i took everything apart and rubbed and blew away.
sounds bad but i did it.
if it does not get the full range back - i will send the receiever back!
thanks guys for all your help on this.
you are really good people.
now its off to ireland and scotland! later!
