Swamp boat
ON, CANADA
Swamp boat
Looking for plans to build an air boat (flat bottomed) using a weed wacker engine for the power unit.22 to 28 cc
Also have a K&B 40 marine engine. need a perry carb for it.
Swamp boat
i am currently looking into doing the same thing. i have the plans but dont know if they will work or not. if i find anything ill let you know.
the big difference will be that i my design is for two 32cc modified motors.
Swamp boat
check oiut my post http://www.rcuniverse.com/showthrea...7596&forumid=43 and my webpage http://www.geocities.com/will_y66/home.htm someone has already copied the design...... just scale it up as you need it
Swamp boat
I have some dumas big swamp buggy plans that came with my kit, im pretty sure they list all the wood you need and what demensions, anyways I had mine driving around my yard the other day, that thing really flies on the grass, I cant wait to see what it will do on the water. Im using a .61. Back to the plans, I have a scanner, and if you will give me a day or two I can scan the plans and instructions and send them to you if i can find everything.
ON, CANADA
Swamp boat
Hello Nitroman. Looks like a lot of people are intrested in you plans. I would realy appreciat them if you would be so kind to send them to
Ken Cox
E-mail is
[email protected]
Thnks
TTFN Ken
Ken Cox
E-mail is
[email protected]
Thnks
TTFN Ken
Swamp boat
well it turns out that they are not detailed anough to do a boat from scratch. anyways the instructions are 2 pages long so I couldnt have scanned them anyways. Im really sorry guys i should have looked them over before I posted.
UT
Airboat plans
I am currently building an airboat from scratch...not quite as big using an OS .40 engine to power it. I searched all over for decent plans and in the end I just came up with my own version of all that I'd been seeing.
Here is a sight that you can download a drafted copy of this guys plans but it's only for the hull you have to figure out the engine mount, radio box, fins, etc. But you can scale them up as needed.
http://home.wanadoo.nl/stuipsmulders...set_index1.htm
