Formula Fastech Brushless
TX
Does anybody know about this boat? Any feed back..Pros/Cons..I think it might be a better villain ex..I havent been able to find about reviews or info about it online. I guess its too new, im wondering if anybody has one, they can maybe pass on some advice.
SC
I just purchased the Fastech Brushless Deep Vee, and am very happy with the boat so far. The speed and handling are excellent using NiMh batteries- I will be going to Lipo power soon. The only negatives so far:
1. Short runtimes (but should be longer with higher capacity Lipos)
2. The hull takes on some water, most likely through the steering linkage boot- so far, no water has gotten in the electronics box
3. Cheap and poorly placed decals
I would estimate the top speed to be around 30 mph with 2 3000 MAh NiMh batteries- pretty impressive out of the box.
Darin
Darin
LA
For 300 bucks, it can't be that bad of a deal. Glad to see someone's got one. Plus, the motor's are very good for the money IMO. I bet you toss on a x642 or MAYBE a x645 with some lipos and that baby will really rip. Get a video!
I had a BJ26 BL for a while. I used 4s1p PQ lipos and a x642 and I was seeing consistant 38-39MPH runs. Motor AND esc where almost cold. Thats why I think a x645 is the next step, but at the same time, thats a lot of pitch for a small hull like that....so if you try be careful!
can you do WOT turns with it? Seems like it would fit into a stock racing club class quite well!
SC
Thanks for the feedback- I'm new to RC boating, have more experience with nitro and brushless electric cars. Can anyone point me to a link to the X642 prop?? Is this a 2 or three blade prop? I was thinking of going with 2S Lipos at 4000 Mah, but they are so darn expensive.
Thanks!
Darin
Thanks!
Darin
I went ot the LHA today and they had several of them and here's what I saw;
It's not a true Vee hul but what I'd call a semi-Vee as it has a flat bottom.
the transom hardware looks nice but the turn fins are a good 1/2" too long and of course turned inward instead of how they should be. Pro Boat still hasn't learned.
It looks from a short distance too much like a Traxxas Villain or Nitro-Vee.
Seeing how I don't know diddly-squat about BL setups I'll leave that for the rest of you.
My Feedback: (24)
ORIGINAL: dazedandconfused
Kmot..how did it handle? and give us the low down..did you like it?
It is similar looking to a Villain as Ron said. A bit shorter though. In my opinion, it is the Villain Brushless that Traxxas should have made already. Proboat beat them to it.
In my opinion, it is a beautiful boat. The one I saw had perfect graphics, no wrinkles and in the sunlight it sparkled.
The turn fins on the one I saw were mounted correctly. So that when the boat leans in a turn, the fin is perpindicular to the water.
So I just got one of these - it's sitting on the bench until I can get a few minutes to go over it - translated to you single guys that means I got to hide this from the wife for a couple of days because of my last spending binge!
I picked up a couple a fresh 4200s at the lhs and got 4 4500s enroute.
Thinking of what hardware and prop I should upgrade with - any suggestions? Is it REALLY necessary to have a prop balanced?? I have NO intentions of racing and don't plan on trying to set any records - at least this year.
How about the outdrive?
I've read the fins are too long? Do I need to replace -
And finally, since I pretty much have been scratch building rc crawlers and mud-boggers for the few years I'm used to fabing alot up. Does anyone else do this?
PA
i have a friend that just bought one of these. it looks really nice but i'm still reluctant to purchase one for myself since IMO proboat still hasn't proven themselves with a reliable craft.
ORIGINAL: 1983shovelhead
Someone may have a different opinion,But you know what they say about opinions!
