Electric Gearing Help!!!!
Old 04-11-2002 | 02:05 AM
Default Electric Gearing Help!!!!
I am running a B3
i have a 81 and 87 spur gear
18, 19 and 21 pinion
what should i run for proper gearing on my motor
16tripple and
17 double
thanks
some people say go up to like 21 on pinion others say go down to like 18
thanks
Old 04-16-2002 | 07:12 AM
Hi,
I don't claim to be a real expert but this works for me with a TC3 on road. If you are racing it depends on the race time. If you run too high gearing 1, your cells won't last the time & 2, your motor/esc will get very hot!!! So find a balance between speed, runtime and motor heating up. I usually keep going higher in practice until the motor gets too hot to touch then come down 1 or 2 teeth.
Hope this is some help!!
