new engine
Old 09-25-2011 | 03:58 PM
Default new engine
quick question, i have a old discontinued thunder quake that has a torq .21 engine and it is starting to go because it overheats and and does not idle, no matter what tune i have it and i have resealed it i dont know how many times. Any way, whats a good .21 engine? also it needs to have a slide carb, not a roto. I just dont know what engine are good and what are horible. -thank you
Old 09-25-2011 | 06:38 PM
Default RE: new engine
I know alot of people don't like rtr engines, but I love the Losi 350 that came in my 8ight 2.0. It definitely holds its own against everything that I have ran it against. It always starts up quickly and it holds its tune really well.
-Also, my friend has a Dynamite engine in his Jammin truggy. That truck is unbelievably fast. I don't remember what model the engine is, but it has a blue head, and it is the one that has the rpm range of up to 38,000. I think the name has the word "turbo" in it.
Old 09-26-2011 | 05:22 AM
1QwkSport2.5r's Avatar
ORIGINAL: ptopman
My brother in law had a thunder quake with the same engine. IMO, a .21 engine isn't big enough for a 1/8 scale monster truck. The Losi 350 engine is a .20ci small lock engine which I do not think will have enough oomph for the T-Quake. I think a dynamite Mach 427 or Losi 454 would be a good powerplant for that truck. They are modestly priced RTR engines that run well and tune nicely. If you're a good tuner and want to spend more money, a Picco .28 would be a good higher end engine.
The Mach 427 is a .26ci and the Losi 454 is a .28ci. LRP has good engines, but are made by the same factory as the Mach/Losi/dynamite engines. The exterior of the engines are different, but the lrp's cost more.
Old 09-26-2011 | 06:55 AM
ORIGINAL: 1QwkSport2.5r
ORIGINAL: ptopman
I agree on the Losi 454. I didn't know what the thunder quake was and he asked for .21 engines. But, for a monster truck, I'd definitely go for the 454.
Old 09-26-2011 | 07:41 AM
The thunder quake is 1/8 scale, and has huge stock tires. It's heavy, probably 12-14 pounds. For these reasons I say a .26-.28 engine will make th op much happier. A .21 in a monster truck will probably be a little anemic, especially with a single speed transmission.
Old 09-26-2011 | 08:00 AM
tommygun32's Avatar
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
ptopman, what's your budget and are you looking for a pull start or roto start?
Old 09-26-2011 | 09:59 AM
BTW the T-Quake is a 2 speed trans. 8D
Old 09-26-2011 | 10:04 AM
its up to $300 and i would like a pull start, i have a spare roto here. im not looking to buy any time soon im just looking around for now.
Old 09-26-2011 | 10:52 AM
I just put an LRPZ28 Spec 3 in an old RAZE ST that i bought used as a re-intro into the hobby.
After all my research, and now being on my 4th break in tank, i believe this is going to be a fantastic engine! I do not think that you will find better for the money, but with your budget, i had seen many posts and comparisons for a Picco which is more expensive.
The LRP Z28 spec 3 has been out for a while now, and i could find virtually no real addressable complaints, and tons of happy customers. I tell you that after hearing it run through a couple of tanks and start to come around to a normal tunable condition, i almost felt bad that it was in a used old truggy! I was incredibly impressed with its early performance, i can't express how satisfied i am so far with my purchase, and i hope my satifaction will continue for a very long time with this engine.
IMHO, i believe that you just can't find a better motor withing the price range of an LRP Z28 Spec3....a home run for sure.<br type="_moz" />
Old 09-26-2011 | 01:40 PM
ORIGINAL: ptopman
Yours must be newer than my brother in laws truck because his was a single speed with the same Torq .21 engine.
Without having a reply with several quotes in it, the LRP spec 3 is the same engine as the Losi 454 with a different head and crankcase markings. SH makes the LRP, dynamite/Mach, XTM, and many others. The Losi 454 is probably the cheapest of the lot. A Picco would be a great engine for the money but you have to be a good tuner with those.
