center diffs on buggies?
Old 09-03-2003 | 11:53 PM
My Feedback: (8)
Default center diffs on buggies?
hey guys.... i am wondering if it is a good idea to lock up the center diff on my buggy... i hear people use silly puddy.... would this work?
Old 09-03-2003 | 11:57 PM
That would essentially defeat the purpose of having a center diff but yeah...you can lock it up with silly putty.
It's more benefitial to just experiment with thicker weight diff fluids to give you what you're looking for.
Old 09-04-2003 | 01:12 AM
yeah u can lock it up but you lose alot of handling and increase understear alot
Old 09-04-2003 | 03:08 AM
Billyman's Avatar
I’d only use the silly putty thing to lock a differential on the front (4X4) and the rear (any) if that’s what I desired. Even on a 4X4, I’d leave the front alone and to me, the center is better left as is unless you took waverave’s advice and experimented with fluid thicknesses.
Old 09-04-2003 | 03:10 AM
My Feedback: (8)
well i have a center thorsen diff, but i am having some problems with it... i am looking to see if anyone has any diagrams of them and such.
Old 09-04-2003 | 03:19 AM
Billyman's Avatar
What sorta probs?
Old 09-04-2003 | 11:07 AM
My Feedback: (8)
i have another thread which states that problem but here it goes.... the spur turns but it doesn't turn the outdrives.... NO power is going to the wheels at all... it is just free wheeling.
Old 09-04-2003 | 11:56 AM
I'd say you lost a gear or two in there, maybe a pin. Pull it out and check it, the problem should be very obvious.
Old 09-04-2003 | 11:59 AM
My Feedback: (8)
see the thing is if i roll the diff manually backwards, it starts to re-engage..... so i have no idea, tonight when i get home from work i will take it out.... but i still don't know how it is put together since i have no instructions with it.
