freezing air filter foam
BC, CANADA
This is really weird, and I'm very curious if anyone knows or has had this before. My garage is room temp, it's warm outside (78-80F), and I go in my garage to gather up all the air filter foams to take into the house for cleaning and the filter I take off my MBX R2 is freezing cold! I checked the temp of the foam with the temp gun and it shows 55F, it even made the whole air filter assembly cold too, and I haven't run my MBX at all today. I use Associated air filter treatement on all my foams, and this is the first time I've ever seen something like this. Is there a chemical that gets cold when in contact with dirt or a certain material?
RE: freezing air filter foam
I can only speculate but maybe the temp of the garage floor caused it to cool, was it on the ground??? Yeah, I suppose that something in the treatment might cause it to get cold, but I really don't think that it makes a difference....
Could it be something in the oil reacting with something in the fuel, assuming a small amount of fuel leaked up towards the air filter....
Maybe you should try posting in the forum for fuels - there seems to be more chemists in there
BC, CANADA
You might be right, it probably reacted in conact with fuel. I store my buggy on a stand on the top shelf.
And here's the result of the filters after a weekend bashing, it nearly made me puke! [sm=eek.gif]
BC, CANADA
Simple, fill the sink up with warm water and use liquid hand soap, drop all the filters in and let them sit for about 10 minutes, take one out at a time and squeeze and wipe firmly with a paper towel, once you've done with all the filters put them back in the water and let soak for another 5 mins and repeat the wiping and let dry, then apply the filter oil all around, and wrinse the sink...of course.
Thank you muchly
My filter was starting to get a little dirty and none of the manuals mentioned you could clean them, I was half expecting to have to buy a new one before long - assume it was another consumable
You could save me a fortune! Ta
GA
the nitro fuel thing is just a quick fix when you dun have soapy water around however the oil it deposits is not a whole lot. Also be careful when re oiling too much oil is a bad thing it can either starve the engine of air or suck the oil into the engine
