Time for something else...
Old 06-12-2013, 03:45 PM
phmaximus
phmaximus's Avatar
Default RE: Time for something else...
Man that battery size really makes things hard...
Kyosho laser ZX5, I suspect with battery straps and some clever thinking they might fit
Tamiya TRF 201 XR, might fit???
Do u have a SCT?
AE SC10, or similar converted into a rally car?
Last idea.... Use all 3 for a 9s conversion on a 1/5 scaler?
Old 06-12-2013, 06:29 PM
echthelion
echthelion's Avatar
How about the Axial exo terra kit?
Old 06-13-2013, 05:52 AM
Eman77
Eman77's Avatar
ORIGINAL: Foxy
Blah Blah Blah
DO IT!
You said you wanted something different. Don't get yet another truggy or buggy. Get an interesting build. Multi gear transmission. Good looks. Complex.
Fun!
Old 06-13-2013, 06:58 AM
Sixtysixdeuce
If I wanted to build a totally ridiculous electric, I'd do it on the same chassis I've built totally ridiculous nitros: RC10GT. Lightweight, tough, handle well. I've got one built as a street fighter with a Picco .21 that turns TRX 2.8" Talons into 7" diameter pizza cutters (not radar checked yet, but I'm thinking 80+ MPH), the other with an OFNA .32, 14T clutch & 48T Losi steel spur, GPM alloy trans case with RRP gears, custom steel 12mm hex drives on rear, custom steel front axles running the 2.8" Talons front and rear , TRX camber links, etc. Very little plastic left, 6.7 Lbs and still wheelies on demand at 30, 40 MPH.
So, if I wanted to do a wicked flashlight, I'd start with that chassis, put RRP gears in a GPM alloy trans, affix the same Losi steel 48T Mod 1 spur to the slipper (with screws all the way through), then mount something like the Mamba Max 2,200 or Tekin T8 2,650 KV and figure out how to put at least an 18T pinion on it.
Old 06-13-2013, 07:02 AM
Foxy
Foxy's Avatar
ORIGINAL: echthelion
That's definitely an option.
Edit: in fact, i'm liking this idea quite a lot. How is the car for motor and battery space?
Old 06-13-2013, 07:42 AM
  #31
DieHarder
DieHarder's Avatar
I've thought about getting one, but I do hear that the battery door is a little troublesome to open...
Old 06-13-2013, 08:11 AM
  #32
echthelion
echthelion's Avatar
ORIGINAL: Foxy
i dont own one but you can put a 550 motor in it and from what i hear the battery is a pain to get in and out but if you dont put the in the interior lexan piece(seats and stuff) it makes it alittle easier. aswell theres a ton of hopups if you wanna pimp your ride =P
info at tower hobbies says the max battery size is
<pre>149 x 35 x 52mm</pre>
Old 06-13-2013, 09:05 AM
  #33
Foxy
Foxy's Avatar
This is what it\ll probably be then. Anyone got any feedback on the RTR electronics? The motor is a 550 castle design I believe, is the servo any good?
Old 06-13-2013, 09:35 AM
  #34
echthelion
echthelion's Avatar
RTR motor is a 540 2900kv 2pole no clue on the servo http://www.axialracing.com/products/ax24010
Old 06-13-2013, 10:40 AM
  #35
Foxy
Foxy's Avatar
Just ordered the Axial Exo Terra RTR, will find something to do with the electrics if they're bad. Thanks for all the suggestions folks.
Old 06-13-2013, 11:14 AM
  #36
cumminspower5.9
cumminspower5.9's Avatar
Gotta post pics of that beast upon arrival. To be honest, I was hoping you were leaning towards the Kyosho DBV VE 2.0. But I could see the Axial as being better since it is a different design.
