Need help finding parts
I have the Sullivan Aluminum Ball Connector w/Sleeve 4-40 Blue as shown here.
I need to find a source for the balls only because I don't want to buy a whole unit to replace a broken ball. I don't need the body, nuts, washers etc, just the ball.
In case it helps, the ball diameter is .152 inches. and it has a 4-40 thread.
Thanks for any help.
Well, I measured it with a micrometer so that is the actual size. The question becomes did it wear out or get crushed in the crash. I just measured it again spinning it to measure from different points and it always comes out to .152.
Pretty sure that's what it has to be. It's not a metric part either because it fits a 4-40 nut and the thread in the body is 4-40 too. I had some parts from my RC planes that were metric and they are too big.
Your .152" (3.8mm) ball studs are out there. Finding them with 4-40 threads...I give up
I tried hard to find them too. If while you were looking you came across any that had .152 balls with a different thread, I could easily adapt them to my application. The part that screw into is a plastic part that is 3d printed. I could simlply print a new part that fits any thread.
Anyway, thank you for trying to help find this thing.
Best regards
Best regards
