Duratrax maximum st ?
Old 06-13-2004 | 12:20 AM
Default Duratrax maximum st ?
What does everyone think of the maximun st? I am thinking of buying a used one and want to know if its any good. I will only use it for bashing but I want it to be able to handle rough terain like construction sites, rutes etc.
Old 06-13-2004 | 10:13 AM
Default RE: Duratrax maximum st ?
hey.i went to some races a little while ago aniond i saw one there. it was pretty good. im not sure what ur lookin for but it was fast and had great acceleration. the bad part was that this was in a parkinglot so it wasnt off road. go to www.duratrax.com and c if there're are any videos. if not go to yahoo and search for maximum st videos. also is this ur first car. if it is i would go w/ electric. theyre much more reliable.
Old 06-14-2004 | 01:02 PM
RYANO218's Avatar
I was working on one for a friend recently and they are pretty good trucks. They can definately handle some rough terrain.
Old 06-14-2004 | 09:43 PM
I have an Maximum MT that I have converted to a ST.
Everything about the truck is simple, straight forward and fairly easy to work on and tune. I have the 1 speed transmission. I have read that the 2 speed transmission that comes with the Pro version can be problematic.
They have good straight line speed, decent handling, and are great for small to medium jumps. They make good bashing trucks. the Torq 16 is a surprisingly good (not great) motor. The shocks and suspension are very adjustable so I have been able to find a set up that suits me and I make the most of it.
I have run only about 2 quarts through mine with out too many problems. I broke the metal spur and replaced it with a plastic one (also bought 2-3 spares). If you get an Max ST I highly suggest you remove the phillips head screws that hold the engine to the chassis and replace them with hex head screws and tighten them down good. That will help keep the gear mesh correct, otherwise the engine will slide around a bit on the chassis and you will strip a spur gear or even worse, a clutch bell. I also recommend tightening down the slipper (1 speed tranny) just about all the way.
I was recently running way to lean (probably over 300 degrees) and I broke the crankshaft. I was able to fix it for 10 dollars.
When I run mine, people want to know what it is, and when I tell them it's a Duratrax, they usually shrug their shoulders and walk away.
Old 12-29-2005 | 08:29 PM
I barly got an os .15 and the crankshaft is broke. I want to know how to get it out. could I use the old crankshaft that is in my .12 stock engine and put it in my .15????? PLEASE HELP
Old 12-30-2005 | 11:15 PM
Nitro Rustler Racer's Avatar
i have one, great truck
