RC find!!!!
IN
I was cleaning out my mothers garage today, she is moving out of state and told me to come get all my childhood things. I found an old R/C truck I completely forgot about. I had purchased it with hard earned money around 13 years ago(im 26 now). I never did get the money saved up to go back for the remote and the servos. I now have a 5 year old son begging me to find a remote and servo kit so we can build it together. It has never even been removed from the box before.
Now My thoughts are should I ebay it or find the parts. If I did find the parts how much would they set me back. If I decide to sell just the kit how much should i expect for it in brand new like condition.
The kit in question is an Kyosho Model No. 3162h Outlaw Raider ARR
Any info on this kits value or links to places that I can get the remote and servo kit from would be greatly appriciated.
Found a photo of my kit online here is what I have. I believe I need a radio servos and battery to complete it.
IN
Just dug in the box some more found a remote manual. Maybe the kit they wanted to go with this. it says the kit number for the radio and servo is W4c-3sn fm.
This kit should contain:
transmitter NET-B124 fm
Receiver NER-327x
Servo NES-507 x 3
Any help locating this kit would be great!!
Receiver NER-327x
Servo NES-507 x 3
It should'nt be to hard to find a Radio, receiver, and servo's to run it. Some radios come with servos and a receiver. However you could look around Ebay to get a cheap radio and all you will need fairly cheap. That is a pretty good Outlaw you have I had one of those and the Nitro version Outlaw Rampage. Well good luck and I would probably keep hold of that you don't find those in that kind of condition to much anymore. And as far as the recomended parts in the manual Im not sure if those exact parts would be available anymore.
{EDIT}: Oh, and as far as value goes you have to take into account that it is 13 years old and never run. So if you should ebay it there might be someone wanting it for there collection. Later
If you go to towerhobbies.com, you can pick up a radio for under 50.00
Batteries and anything else you would need...
like the other guy said it might be worth more than you think on ebay
IN
Would any remote have the right servos needed?
I have never built an R/C car.
Do you think I can get more then 100 out of the truck?
IN
would this one work http://www2.towerhobbies.com/cgi-bin...I=LXCFW0**&P=0
It says it comes with 2 servos, Do i need 3 like the manual to the remote that was in the truck kit says.
Sorry I'm new to this always was a fan and love driving my friends R/C cars as a kid but this will be my first build.
here is the stats on the radio that looks like its in my budget
This is the Airtronics Blazer 2 Channel AM Pistol Grip Radio.
FEATURES: Steering and throttle trims.
Steering Dual Rates.
Servo reversing.
Functional NiCd charging jack in transmitter (NiCds not included)
Transmitter battery indicator (3 LEDs).
Adjustable throttle trigger.
INCLUDES: One transmitter No Number
One 92723Z Micro BEC Receiver (75MHz) AIRL05**
(27MHz) AIRL04**
Two 94102Z Standard servos w/Z connector AIRM2102
One 4 cell RX battery holder No Number
Two extra X-shaped servo horns with mounting screws No number
One switch harness AIRM1205
One package of servo mounting grommets No Number
One Frequency flag No Number
Instructions and warranty info.
REQUIRES: Eight AA batteries for transmitter, four for receiver.
SPECS: Transmitter:
Model: Blazer
Output power: 500 MW
Power supply: 8 AA alkaline dry cells DC 12V
Weight: 14.46 ounces
Frequencies: 27MHz-6 frequencies, 75MHz-30 frequencies
Receiver: (mini BEC type)
Model: 92721Z (27MHz) or 92723Z (75MHz)
Modulation AM/PPM
Intermediate frequency: 455 kHz
Power supply: DC 6.0-8.4V
Weight: 1.13 ounces
Dimensions: Length: 1.9" Width: 1.3" Heigth: .75"
Weight (without leads) 1.94 ounces
Servos: 94102Z Standard HD servo
Weight: 1.59oz
Dimensions 1.54"x 0.79"x 1.42"
Torque: 50in/per ounce
Speed .18/sec @ 60 degrees at 6V
COMMENTS: For Transmitter NiCds, use (8) SANP1100
For a charger, use AIRM4100
For a Receiver NiCd, use any 4.8V Rx NiCd with a Z connector.
The difference between the Blazer and the Blazer Sport is the Blazer
has independent end point adjustments with a clear protective cover
kh05-24-02
Servo reversing.
(27MHz) AIRL04**
SPECS: Transmitter:
Model: Blazer
Modulation AM/PPM
Weight: 1.13 ounces
Weight: 1.59oz
kh05-24-02
unless im blind thats an electronic truck, with an msc. meaning you only need a reciever and 2 servos(one for steering and one for controling the MSC)
heres the one im planning on getting when i upgrade from the stock traxxas 2ch transmitter.
http://www2.towerhobbies.com/cgi-bin...I=LXENN063&P=0
wicked
wicked
VA
dude get a used hitec radio off of ebay..be sure to get a fm not a am cause am is crap (in my opinion)...you can get a cheap old futaba off ebay too...its a old truck why do you need a new radio?
Dude....Just about any remote will work. the standard servos that come with basic remote is all you will need.
you obviously just want to have fun....you dont need a HI quality remote to do that.
A truck that is 10 years old and in mint cond......worth well over 100.00
Have fun!!!!!!
Have fun!!!!!!
ORIGINAL: bigbodychevy
IN
OK I got the remote and servo thing figured out. Now i need a battery for this thing. Can the battery power both the reciever and the motor so I don't have to run 12 AA batterys. Just 8 in the remote. I can see this hobby being another money pit ;-).
Another note I have a tendency to over do all my hobbys. If i keep it and get a remote and battery I'll eventually want to trick it out convert it to 4 wheel drive and beef up the motors. Imma sucker for more power and more noise. I spend enough money on the 74 impala im in the middle of restoring ;-).
Any links on how to convert a 2 wheel drive electric 1/10 truck to a 4 wheel drive truck. Im hooked and in it full speed ahead.
P.S. I just got done putting the kit together. I'll I have to do know is order the remote and battery. the manuel says it need 7.2 volts.
2wd is faster than 4wd.... if you must drop money into it make it int a brusheless monster with GP3300s and then you could toss shorter pinned tires on it for harder tracks. paint the body up nice. etc
wicked
wicked
Proline ( www.prolineracing.com) makes an Escalade body.
Btw if you're in it seriously now [>:], put some wide bumpers on that thing and give it to your kid stock and get yourself a nice electric Stadium truck or 1/10 Buggy [>:].
And sorry, it is very hard to turn any 2WD into a 4WD (unless it is mede for it...but there's only one vehicle Ive ever seen that was made for that...and its only like a year old).
IN
This was no cheap truck when I got it. Should be plenty for me for a while. found all the parts I need at a local hobby shops websight. Including the escalade body.
Gonna run the stock body when the son is at the controls.
By the way here is the stick I picked out. Its not a name brand but it is FM and you guys said FM is better then AM.
IN
Just got back from a local hobby shop... Hobby Town USA. Got a futaba Magnum 2pl, Batterys charger and escalade body kit talked in to tossing in the body kit and paint for free.
IN
P.S. Some how the speed control rod has ben lost. The guy at the shop gave me some piano wire and told me how to make one with some needle noes plyers. If this does not work he said I can always convert it from manual speed control to electronic.
For another 50-60$ for the electric speed control kit!
Any benefits in doing this in the long run. This guy almost sounded like he was on commission. Tried to sell me on converting. I dropped about $130 today. Not bad considering what all I got. MSRP on the remote and servos was $119.99 they where asking $99.99 for it. I also got the battery and charger some servo mounts, paint and an escalade body kit. ;-) They never saw this Electronic Sales man coming I know the commission game.
And Yes RayRay it is a bec reciever so I dont have to run the second battery pack.
IN
Well Update time. I ended up with a 2pl Radio and 2 3003 servos. I also converted the speed control to a fatuba mc230. Have had alot of fun lately. Even found a second truck new in box for spare parts pretty cheap. Having a blast. Looking into upping the engine soon. any suggestions.
