Removing annodizing?
Old 08-03-2004 | 05:44 PM
Default Removing annodizing?
Does anybody know of an easy way to remove annodizing from parts? I'm using oven cleaner right now, but it's taking forever. I thought about using the wire wheel on my bench grinder but I don't want to have to polish out the wire marks. Any help or previous tricks that worked is appreciated.
Old 08-03-2004 | 05:46 PM
ICrashThings's Avatar
Default RE: Removing annodizing?
i thought u could heat them...or something?
Old 08-03-2004 | 06:40 PM
fhm101's Avatar
It really depends on what the quality of the anodizing you are trying to remove. most of the crap on RC parts is little more than a dye coat being called anodizing. This is the stuff that comes off with oven cleaner. if you have true color anodizing it's a bit tougher and may even require an acid dip to remove. If you are trying to remove hard coat anodizing, good luck.
Old 08-04-2004 | 09:31 AM
Keep trying the oven cleaner. I've heard Demon Clean works well. Another thing you could try is polishing the parts with a dremel equiped with a soft buffing pad and some polish.
