How does oil content affect your engine?
ON, CANADA
I'm just wondering how the different oil percentages affect your engine and performance. If I want more longevity for my engine, should I use a fuel with a higher oil percentage? There are two different fuels my lhs carries: 20% oil and 16% oil. Both are 20%nitro. Should I run 20% oil if I want better engine protection?
more oil = worse perforrmance but better engine protection/cooler running, you are quite right.
oil percentage is usualy set by the engine manufacturor - whilst you might be ok with more, you definately dont want less!
ON, CANADA
what do you mean by "too much" joeman? what kind of effect will too much oil have on my engine?
I might be getting a used RC10GT with a Novarossi CX12 in it. what kind of fuel should I get for max protection? I'll give up the extra performance for longevity.
FL
16% is on the performance side, 20 is on the longevity side. I usually get 18% if i'm not racing because it's in between, plus it is a common percentage. but i wouldn't get too worked up about the longevity thing. It won't dramatically effect your engine's life, and you'd want to get a new engine every 2 years or so anyways. If your not racing, go ahead and get 20%, you probably won't see a difference in the performance.
TX
ON, CANADA
thanks mike. some good info there... you gotta wonder though, the author is a little biased right? I mean, he designed the stuff!
FL
I also use fuel with low oil content when I'm racing, but when I'm not I switch back to 18%. I still need a little more convincing.
TX
ORIGINAL: resonantfreq
ON, CANADA
well, I think I'll just go with the 16%. Not that I don't believe you guys...its just the lowest oil content fuel my lhs carries.
