.21 starter boxes
Guest
My Feedback: (73)
What is the best and most powerfull starter box for high end .21 engines ? I have a RC Concepts .21 and i cant get my ofna starter box to turn it over, i have had problems with os .21s also ... there has got to be something better out there !!
Wojtek
Wojtek
My Feedback: (158)
My freind was having the same trouble with his RB 12 and the 1/10 scale box this weekend. it's not the compresion but the "fit".
Is it tight at the top even without a glow plug in?.
If so this should losen up after a few runs
I had simalar trouble when I used to race quickie 500 with Nelson engines. When they were new you could hardly turn them over
You'll need to set your box up so the switch can get the motor spinning full speed before the flywheel comes down on it. and make sure the piston is not locked up when you try to start it
Of couse make sure your battery is fully charged
Are you using the stand offs so the chassis is completely off the box?
After a while it should loosen up for you
Good luck
Good luck
What you should do is pre-heat the engine first. Use a heat gun for airplane covering or even a hair dryer. This will expand the engine to the point that you should be able to turn it over with the box. Using a drill is not a good idea since you could damage the threads and kill the engine if there isn't a constant flow of oil.
Guest
My Feedback: (73)
im using the drill with a pilot shaft that im using just for the drill attatchment, i rung the after run oil through the plug hole constantly ... i run the drill really slowly too ... about 3 turn a second ...
I have done this with DF jet engines for a while ...
Wojtek
Wojtek
