longevity of nitro motors???
Old 11-08-2002 | 02:49 AM
Default longevity of nitro motors???
Hi all,
I'm thinking of buying a nitri truck with a O.S. .12 cv motor and was wondering how many gallons of fuel I should be able to run thru it before they need to be rebuilt. I was told at a local hobby shop you'll only get about 2-4 gallons before you need a rebuilt, and that made me a little leary on buying one.
Sure appreciate your inputs on this.
Old 11-08-2002 | 05:28 AM
Well, from what I've seen, if the engine is broken in correctly, and taken care of, i.e. after run oil, not over heated, about 6-8 gallons isn't rare. So after about 8 gallons, for an OS .12 cv, you spend 27 dollars on the piston and sleeve from duratrax, tapered chrome plated, and you're back in business with a brand new engine... almost
Old 11-08-2002 | 01:33 PM
Thats sounds alot better I can deal with that!
Old 11-08-2002 | 01:59 PM
I should point out that after run oil is optional. It depends allot on what fuel you use. O'Donnell and Trinity Monster fuel do just fine with no after run oil. All fuel is not created equal, and some fuels will cause the inside of your engine to rust after sitting a week. Then again, it will not hurt to use it if you just want that "just in case" senario.
As tator said, if you break in your engine correctly, and depending on if it's a race or play engine, 6 to 12 gallons are probably the average.
I've had them wear out after 1/2 gallon "defective piston", and i actully got over 20 gallons thru an OFNA P4 before the rod was wore to much to idle and tune. The piston and sleeve still had life in it.
Old 11-13-2002 | 08:25 PM
I have never been able to get a os last more than 2 gallons. But all the nova-rossi motors iv had, lasted at least 8 to 10 gallons.
Old 11-13-2002 | 09:52 PM
I've seen a few O.S. CV engines get up to 6 gallon, but that has a nickel sleeve. ABC (chrome sleeve) engines can go 8-10 gallons. However it is possible to toast any engine in one gallon if you run it too lean, too often.
If you at least respect the engine even just a little, you shouldn't have any trouble getting more than 3 gallons.
Old 11-14-2002 | 01:13 AM
My .15 cv-r i put 2 gallons thru just last weekend... still has full compression... this is the first 2 gallons of it's life after rebuild, only had about 1/4 of a gallon run thru it before it needed rebuild, overheating is a *****, TIP: if you break off the exhaust header, don't keep running it, 420F is TOO hot
Old 11-14-2002 | 10:10 PM
WHHHOOOAAAAA!! 420?! I highest I have ever seen is 325! Running at 325 toasted my engine in one gallon. It was a carb problem so the factory fixed it free of charge.
Old 11-14-2002 | 11:44 PM
yeah, it pretty well toasted it in under 3 minutes of running, i figured that it would just be louder, maybe lose some power, didn't realize that would happen... I'll take some pictures of my warped black piston / cylinder and post them in the gallery
Old 11-15-2002 | 08:34 PM
That really is extreme!!!
Aslong as ure not pushing ure engine(not to lean) its easy to get a good life out of it. New piston and liner isnt to bad n e way!!
I thought it was cool running my car without the muffler!!! never again!!!
