help
Old 12-29-2002 | 08:16 PM
Default help
my nitro rush wont start it makes a weird clinking noise when i pull the pull cord. i think it coming from the motor part
if u nknow what is wrong please help.
thx
Old 12-29-2002 | 08:22 PM
BUGGIES_R_US's Avatar
Default Hmm..
Clinking... is it loud?
I hope your piston is not hitting anything.. check the engine and make sure you dont have anything in there..
I'm kinda new myself.. and thats all I can think of!
-ram
Old 12-29-2002 | 10:47 PM
My Feedback: (16)
Default Re: help
thx
It could be your pull starter. Check the link to read about how they work. You may be able to fix it. If you pulled it out to far you may need to remove it "CAREFULLY" and fix it.
http://www.rccaraction.com/rc/articles/oneways.asp
Old 12-29-2002 | 11:13 PM
Default help
NitroRush,
I assume you have the "stock" cast flywheel. This can be the problem. First try tightening up the clutch nut pilot shaft. If this doesn't work, you'll have to upgrade to the aluminum flywheel and collet. I think the "cast" flywhheel has a factory defect that they might offer to fix. Being you have a NitroRush, why not try the HP EYE forum. There are many "experts" there (lol).
Old 03-10-2003 | 10:22 PM
Default help
make sure your angine head is on tight and the washer is there under the head
