NITROUS SYSTEM FOR RC CARS!!!!
#51
RE: NITROUS SYSTEM FOR RC CARS!!!!
ORIGINAL: 125cchyperman
But the discussion is about weather or not they work on 2 stroke's. But I think we all know that it's about getting more air into the engine at pressure's higher then the outside atmosphere. But it's weather or not it works on a 2 stroke or not. Most people say that it doesnt but there are the few that say that it does.
But good pic though.
Roy
www.beatracing.com
#53
ORIGINAL: burrd91
my dad and his boss used to drag sleds and it doed work on 2 stroke engines
Now, in gasoline engines, 2stroke like your sleds you mentioned, will definitely benefit from the shot of n2o for various reasons.
#54
WI
Has anyone that has posted on here actually used one of these nitrous kits? If you have never done it yet, THEN YOU DONT KNOW if it will work or not. I just bought the entire kit for my Duratrax Street force GP2 with an OS .18 CV-R engine. So at my expense we will see how well it works, and i will make sure to post again after a sucessfull run. By the way- name an engine that wouldnt run better with nitrous? Nitrous is just an oxidizer, and engines need just a few things to run- compression, heat, fuel and oxygen- If an engine runs slower with less oxygen (which they do obviosly, unless your engine gets faster and faster when you plug the throttly....right) then an engine with more oxygen should run faster to a certain extent, unless the engine is already at its maximum power ratio considering the oxygen. Dont forget too- the nitrous charge is much cooler than the outside air, which creates a denser oxygen charge. Oh, and by the way, I just recently graduated from a national automotive technical college, and have had hands on training with the use of nitrous oxide so i do know a thing or two about it. -I will post with results when the time comes!
#55
I just wanted to add the layman explanation for the use of nitrous oxide, since many people don't understand how exactly it works, and its effects on a 2-stroke nitro engine.
Nitrous is just adds more oxygen to your combustion chamber. The more air you get in, the bigger the 'bang', the more power you get. That's IF you can contain the added O2. The problem with 2-strokes are that the intake AND the exhaust ports are usually open at the same time, thereby, any oxygen coming, in, usually comes out as well if its pressurized or forced into the engine. Sure, the exhaust port closes first, so you do get that 'little bit' of nitrous oxide in there, but just doesn't justify the $150-250 spent on the R/C nitrous kit.
And I agree with the guy on page 1, NOS is too commonly used that even snobs who don't know anything about mechanics call it that. NOS = Nitrous Oxide Systems, its a company, just like NX (Nitrous Express), and whatever company name the guys with the purple bottle is called.
Anyway, going back on your topic, I hope to see your review on this. A friend of mine purchased both the RCInnovations supercharger kit for his Savage, as well as Nitrous Express' kit. He hasn't tested the NX kit yet, but I can safely say, RC superchargers are a waste of money. The performance gained is so unnoticeable that its basically having dead-weight on your vehicle.
Anyway, hope to see your review on this.
#56
ORIGINAL: REDisFASTER
#57
ORIGINAL: fly_nitro_rc
The reason why I say use X-Dyno as the measuring device is because it is the most stringent device out there. Other dynos are not so consistent and produce much higher numbers than our little engines could ever dream of. Additionally, X-Dyno is more proliferous than any other dyno, it is slowly becoming the Standard. XRC uses X-Dyno, Axial has an X-Dyno, and not only that, memebers here have modded engines and sent them to someone with an X-Dyno to have them tested.
#59
The last NO2 systems for cars I looked at were filled with nitrous oxide with a minute amount of sulphur dioxide to make it un breathable by idiot humans looking for a buzz. There were 2 solenoids and spray bars in the kit, one for the nitrous and one to dump extra fuel, needed for the extra oxygen made available, usually gasoline. They were a little tricky to dial in but once there they were awesome. I see no mention of extra fuel on the rc systems. I'm with SAVAGEJIM on this, show me an honest dyno graph.
#62
VA
ORIGINAL: Grits
Theoretically you would need extra fuel because with NO2 you can burn more fuel because you add more oxygen.
#63
just for giggles.... I had a pocketbike with nitrous on it!!! and the guy that said you wont gain any top speed was probably right! it did boost acceleration low to mid range but top end it wouldnt do a thing. and at 15second burst tops! just wasnt worth it. fun but wouldnt recommend it. just thought Id throw my hat in.
#64
i read a review of rcinovations nitrous system in a mag(sorry cant remeber which one). they gave it a good review(but then again, they will never say a product sucks)
they said the note of the engine changed, and accel was improved. and over their testing the engine stayed cool.
it seems like a cool product for the guy who already has everything that he can put on his nitro truck.
#65
My Feedback: (21)
MI
if you want power get a big block
http://vids.myspace.com/index.cfm?fu...deoID=14659525
#67
ID
i have a freind that drag races an ntc3 wit a custom mini exahast driven turbo and he also runs nitros the motor is an os speed tuned rb moded tz .12 wit out the turbo or nitrous it only does 65 mph thats slow compared to the almost 90 with all the power adders
#68
if the engine was topped out at 60 mph and turning 38000 rpm then the add ons boosted the rpm to 57000 rpm@90 mph.....
makes one wonder
makes one wonder
#69
MD
ORIGINAL: Grits
makes one wonder
makes one wonder
