air commpres
WI
air commpres
is it possibe the et an air commpresor that will be able to fill up truck tires on my dads chevy suburban 1500 and to use it for air brushing?
can i get one that has a adjustment for air flow or psi?
all my dad wants it for is to fill up his tires but i want it for cleaning, painting, and a bunch of outher things
RE: air commpres
Well I wouldn't use one of those small air compressors that are just dedicated for air brush use. They only put out about 15 psi and is not enough to fill a tire. For airbrushing I use a regular type Campbell Housefield compressor with a 1.5 Hp motor and 7 gallon tank. That can fill up tires because it pumps the tank up to 100 psi. When I use it for airbrushing which is pretty much all I use it for anyway I set the regulator to about 15 psi. The compressor makes a racket filling the tank up but then I shut it off when I airbrush.
RE: air commpres
Hi,
Those big air compressors should work theoratically but you need to add a pressure adjuster and a thing to seperate water. Of course some proper adaptors.
Regards
Joaquim
Regards
Joaquim
