Yep, Another Problem
Old 10-29-2006 | 03:25 PM
Default Yep, Another Problem
Once again, my old friggin' buggy won't run. This time, I cant get fuel pressure to the engine. I checked the seal on the gas tank and the fuel lines, but everything seems fine. I want to try to fix this without having to take apart the engine. Any suggestions?
Seth
Old 10-29-2006 | 03:39 PM
Default RE: Yep, Another Problem
Hey,
Same thing happened to me. All I did was blow out the carb real well with a compressor or can of compressed air. That should do it.
~Kyle~
Old 10-29-2006 | 03:43 PM
46u's Avatar
46u
If you blow in to the presser line that goes to the exhaust does it get fuel to the carburetor? Does it have a primer on the fuel tank if so these are known for creating problems.
To check the fuel tank and fuel lines for leaks you can take them off plug one line and submerge in a sink of water blow in the other line and look for bubbles.
