Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Plastic kit: requesting help about paiting
Old 11-02-2006, 07:20 AM
rva1945
Default Plastic kit: requesting help about paiting
Hi:
Yesterday I bought the TAM24122, Toyota Land Cruiser 80 w/Sport options (roof lights, etc.)
It's a plastic kit, with the doors moulded.
I do I paint the door openings? The same doubt I have with the rear lights, do I have to mask them and then paint it, and with what paint?
Airbrush? Brush? What kind of paint?
Any experience with this or similar kit from Tamiya?
Robert
Old 11-02-2006, 07:41 AM
thedub88
Default RE: Plastic kit: requesting help about paiting
Do not brush!! There is a certain paint that you must use, it's for lexan or polycarbanate
If you can get the spray cans do it, but if not buy the jars and use an air brush.
Your kit should of come with window masks. They go on the inside of the body. These are the only things you don't paint
Don't forget, your supposed you paint the inside of the body, so when you roll over it doesn't scratch up the paint. This also gives you a perfect high gloss look with out the trouble.
Also there is a clear protective overspary film on the outside of the body, and you must remove it after you are done painting.
Old 11-02-2006, 08:46 AM
rva1945
Thanks thedub88.
Now how do I remove the clear protective overspary film on the outside of the body?
Old 11-02-2006, 09:34 AM
BuzzBomber
BuzzBomber's Avatar
Um, am I missing something here? Since when do 1/24 scale Tamiya plastic model kits come with clear lexan/polycarbonate bodies? Every one I've seen is a plastic like ABS or polystyrene, which would use a normal model enamel paint on the OUTSIDE, preferably sprayed on.
Old 11-02-2006, 09:43 AM
nayslayer
i think buzz is correct, i don't think his body is clear lexan. If its not you'll have to spray it on outside with spray can.
Old 11-02-2006, 11:29 AM
Nitro Fumes
Nitro Fumes's Avatar
Do you mean a 1/24 scale plastic kit like this? See pictures. I also build plastic kits. I did that in 2000. If that's what you mean, which I think you do, then reply back or e-mail me and I can tell you how to do up one of these models. It's completely different than R/C lexan bodies. Much more detail work involved. I even weathered mine to make it look dirty. Notice the mud spray and the windshield. I can also tell you how to do he light lenses properly because Tamiya usually just molds all of them in clear.
ID:	553101   Click image for larger version
ID:	553102   Click image for larger version
ID:	553103   Click image for larger version
Old 11-02-2006, 03:08 PM
R/C fan-addict
R/C fan-addict's Avatar
ORIGINAL: BuzzBomber
polystyrene is another name for styrofoam... I don't think they make styrofoam bodies
Old 11-02-2006, 04:54 PM
Nitro Fumes
ORIGINAL: R/C fan-addict
Polystyrene is not another name for styrofoam. Styrofoam is made from polystyrene but so are plastic model kits. They are injection molded under high pressure and are not foamed.
Old 11-02-2006, 05:19 PM
R/C fan-addict
ORIGINAL: Nitro Fumes
oh I see, lol, my bad!
