engine blown?
#32
Ok, 1682 is all of the washers in the carb, so it can't be that, and 1678 is your complete needle valve. It is possible that your needle valve is loose because it is held on by that nut which is part 1680. So, if that is it, you might want to tighten that on your carb. What you can do is look at the pic I posted, then look at your engine and look for that specific nut, then tighten it. If that is what is loose, it should fix your problem.
If it doesn't, then something else is loose. Examine your whole carb and look more closely to see what is loose.
Hope it works out for ya',
Kevin
Kevin
#33
okay i just need to spin the thing at the bottom on the needle. but now the fuel hose is touching the heat sink...i'm pretty sure i know it will melt but i want to make sure...will it?
#36
i cant get it to not face the heat sink...if i do then its lose...maybe it wont melt i'm not sure....i haven't had a chance to run it yet...my C battery went dead and i have to wait till my friends dad to get home until we get a new one...damnit where is he...
#38
Originally posted by }{unter
STOP RIGHT THERE before u mess something up
Okay I've stopped...should l loosen it back up so it faces away from the heat sink?
#39
NC
There are 3 needles on a Car engine there should be one right beside the Air filter its called the high speed Dont turn the whole caburator. Just screw the high speed needle (Screw) out about 1 turn.
The Car isnt looseing compression its getting hot after running it and it just feels like it doesnt have any compression its really just becasue its hot from running. Make sure u see Smoke coming out the exaust.
#46
I'm just about to sell all my rc car stuff....both my new car and my old POS (for spare parts i guess)...to much trouble with this car. I might not even buy a new car.
#47
Originally posted by dbow
Also with the head off the piston should push the sleeve up out of the case when you rotate the engine over. If the piston goes to the top of the sleeve with ease then back down, its time for a new piston and sleeve.
Dbow
Dbow
so if i pull and the piston comes up and pushes the sleeve up then goes back down with little effort then it is time for a new piston and sleeve? Oh will the tuned pipe from the FE fit my SS engine?
