Pull String Hard To Pull???????
Old 02-20-2003 | 11:34 PM
Default Pull String Hard To Pull???????
HEY ON MY .12 ENGINE WHEN IAM READY TO PULL START IT IT ACT AS IF IT DOES NOT WANT TO COME OUT LIKE IAM USEING TO MUCH FORCE TO PULL IT OUT THEN I SHOULD. AND HELP JUSTA NOT THE ENGINE IT NEW BUT HAS BEEN BROKEN IN.
Old 02-20-2003 | 11:35 PM
flooded?
Old 02-20-2003 | 11:44 PM
HUMM COULD NOT BE THAT I MADE SURE ANY OTHER SUGGEGETIONS?
Old 02-20-2003 | 11:48 PM
maybe the recoil inside the pull start has gone bad and caused the cord to wind back up in a scewed up fashion. you know like rewinding it but not doing it right and crossing it up inside. maybe its fouled up inside. if you open it watch it doesnt spring out like a snake in a can.
Old 02-21-2003 | 03:54 AM
Will it turn over with the glowplug removed? If not with the starter cord, can you turn it with the spur gear? I had that problem one day and I had a rock lodged in the running gear. Good luck.
Old 02-21-2003 | 06:18 AM
BUGGIES_R_US's Avatar
Heck your glow plug might be bad.. If its hard and the engine wont start, try removing the glow plug.. hold engine upside down.. and take it through a few cycles.. pull the stright about 3-4 times.
Put a clean glow plug on, start it with new batteries.. should work.
If glow plug gets fouled with fuel, it will make starting difficult
Put the plug on the ignitor and burn of excess fuel residue in plug
-ram
