Rossi n12ll5
RE: Rossi n12ll5
Well it's like the shaft isn't long enough because the clutch bell doesn't stick out far enough for the spur and clutch gears to line up correctly. And how would getting another clutch make the drive shaft different or help the situation?
RE: Rossi n12ll5
Go to the On-road nitro section and talk to the Miami people as they are trying to achieve 100mph on their rs4-2 using high end engines
I only know how to get SG flywheel/clutch setup for rs4-3's. You might wanna look into he R40 flywheel/clutch setup as it might work for your rossi engine
