gear mesh problem
Old 04-27-2007 | 02:30 PM
sunco1's Avatar
Default gear mesh problem
i have a revo 3.3 and i have been having trouble with the gear mesh. when ever i tighten the screws all the way down the engine moves down and the gear mesh is messed up. a guy at traxas sed my mount was broken but i just wanna confirm the problem. is this it?
Old 04-27-2007 | 02:58 PM
Foxy's Avatar
Default RE: gear mesh problem
Sounds like it. But any failure that causes this behaviour in an engine mount should be easy to spot. If they look fine, the problem may be somewhere else. Here's a tip, fold a piece of regular photocopy paper in half, and insert it between the gears, now tighten down your engine. Now remove the paper. Mesh should be perfect, but make sure your engine is well seated and there isn't a genuine problem with the mount before you run it.
Old 04-27-2007 | 06:34 PM
Folding the paper will give about .008 of an inch clearance. I have always read that it should be more like .004, or only one thickness of paper. I know that doesn't sound like much but it does have an effect on the way the gears mesh and where pressure is placed on the gear teeth. Of course none of that matters if you have a broken mount.
Old 04-27-2007 | 06:39 PM
evil's Avatar
Im not sure what your chassis is made of, check its not bent or twisted around where the engine bolts up.
Just a thought.
Old 04-28-2007 | 02:06 AM
Foxy's Avatar
Nitro cars fold the paper, electric cars, don't. Simple. I've been doing this for nearly 20 years.
