If i mix fuel together..
1 Post
RE: If i mix fuel together..
All you're doing is mixing the different attributes of each fuel. Theoretically all you should end up with is a fuel relatively similar to each of the others depending upon what ratios you mix.
nitro, if you break-in fuel was also 16% nitro and you mix equal parts you'll just end up with a slightly more oily version of your 16% fuel. With a slight re-tune it should rune fine...
see what happened was i wanted to run my whole bottle of break-in before i went to 16% so i tought mabye i should mix it because it should run better, but i never did it.
But thanks for the reply.[8D]
Yeh i havn't broken in yet,was thinking if i should mix the 10% with the 16% hotstuff fuel for break in on my nitro sport since i have 10%left over still?
