Direct drive (no gears)
I was just wondering would it be posible to produce a RC car that has no gears or a 1to1 gear ratio?? if you could it would be insane fast!!
PA
RE: Direct drive (no gears)
Gears help --- they don't hurt. Most engines can't provide enough power for 1:1 ratios. It would take 45 seconds to reach top speed on a level surface and most engines would overheat, not climb hills and never go off road.
ORIGINAL: nitro _ burner
nitro engine usually make there power at about 30,000 rpm, and do not have enough torque to run a car direct drive, most have a reduction of about 10-25:1 from the engine to wheels.
CA
over at rczone brushless, a guy was making a buggy with 2 brushless outrunners shafted directly into the diffs. each motor was pumping more than like 1000 watts of power.
