Starting options
QC, CANADA
Starting options
I have a revo for my son with the electric start and I love it. I have 3 other cars that all use starter box which I can't stand because of all the stuff I need to carry. Whats the next best option, roto start?
RE: Starting options
if you dont like a starter box you probaly wont like the tiger drive system either, unless you do not mind carrying around a cordless drill. Or if you already have a real small drill it would not be so bad.
GA
Powered start systems that are similar to the tiger drive system (which I've heard bad things about) can all be purchased with a handheld starter that is considerably smaller than an electric drill and give better results too. They are;
HPI Roto start
Hot Bodies start
DuraTraxKwik-pit
Losi spin start
You did not say which engines you would be trying to start with them so I don't know if/which have starter backplates available for them.
If you can get backplates for one of the systems then most of the handhelds will work with the exception of the Losi system, it's set up to spin the opposite direction from the others.
Also, some, maybe all, of your engines, may need different engine backplates and also one way bearings
HPI Roto start
Hot Bodies start
DuraTraxKwik-pit
Losi spin start
I like bump starts the best. The OWB in the engine just plain sucks IMO. Nothing is more reliable than a starter box, even though you do have to lug it around.
