Wheel Size..... Need Help Please !!
Hi
I own a Pirate 10 nitro buggy which currently has 80mm diameter wheels on it, If I change them to 120mm Wheels will this damage the car at all??
Thanks for your help..
RE: Wheel Size..... Need Help Please !!
hey i dont know if its just me or HEAPS of people have all of a sudden got a pirate 10 either monster truck or buggy, when i got one ON ONE had even heard of them. anyway like i said i have one, and it wouldnt damage the car but it would slow own the acceleration, to make it perform realy well with larger wheels try buying a .15 or larger engine and a realy good clutch. if your still stuck on what to get go to your LHS and ask them thell tell you everything you need to know.
Hope this helps.
Hope this helps.
Thanks for the advise.... I wasnt sure if it would put extra strain on the clutch and/or engine. The only reason I want to put bigger wheels on it is so that i can take it on lumpier surfaces as the normal wheels make the car ride very low to the ground.
Thanks again.. Paul
Thanks again.. Paul
