question about a header?
Old 11-25-2007 | 03:13 PM
Default question about a header?
can a small crack or any crack in a header cause a car to run lean or hot?
Old 11-25-2007 | 03:26 PM
Default RE: question about a header?
i'm not sure about how it would make it run, but it can't be good. try some jb weld to fix it
Old 11-25-2007 | 04:00 PM
Anthoop's Avatar
ORIGINAL: Deftones123
Yes,very basically-less back pressure will result in a lean mixture leading to higher temps.
Old 11-25-2007 | 04:01 PM
should I just try to seal it or buy a new header?
Old 11-25-2007 | 04:04 PM
if you can just get a new one, but jb weld should work to patch it up
Old 11-25-2007 | 04:05 PM
Anthoop's Avatar
We'll need to see a picture of the crack before we can ascertain the remedy!
