Solution to Stripped Screws
NC
I saw this on tv the other day. it can be used when a dremel can't reach the screw. cheaper than a dremel also.
http://www.4grabit.com/Default.asp?bhcp=1
im thinkin about ordering a set.
MN
You don't have to order them you should be able to find them at most any hardware store, Home Depot, Lowes, etc. They are also go by Easy Out.
Dave
Dave
i bought i set at sears to try and remove a screw from a rc part. It was like 40 bux and they where all to big to work on rc screws so i just returned it.[:@]
ON, CANADA
They'll work on alot of screws.......You just have to Use the drill side & be sure you Drill the Screw enough for the other end to Grab the screw....
http://media.putfile.com/Removing-Striped-RC-Screws
