Quick Question About Antenna Wire...
Old 09-13-2008 | 01:32 PM
BM1
Default Quick Question About Antenna Wire...
Is there any special "trick" to make getting the antenna wire through the plastic antenna tube easier?
I tried putting mine in last night, but it would bind up quite a bit causing me to not be able to get it in fully. I ended up just getting my fingers damp and touching them to a bar of soap to get a tiny bit of soap on them and ran that down the length of the antenna wire. It threaded through easily after that.
Any other tips for the future?
Old 09-13-2008 | 01:42 PM
xxSLiMxx's Avatar
Default RE: Quick Question About Antenna Wire...
try a little bit of shock oil or some greese,.
Old 09-13-2008 | 03:39 PM
Matt_Gruizinga's Avatar
i always spit into the tube and push it out with air then i get the wire wet and it will go through nice and easy
Old 09-13-2008 | 06:10 PM
ace9213's Avatar
straighten the wire and lube it.
Old 09-13-2008 | 06:16 PM
sheograth's Avatar
Moderator
I straighten the wire a by holding the base and pulling along it a few times, then I put a drop of turbine oil into the tube, that generally does it.
Old 09-13-2008 | 08:17 PM
I use baby powder....its not a chemical and it smells good....just rub some on the wire before inserting it into the tube.
Old 09-13-2008 | 09:08 PM
Powder while straightening out the wire at the same time is what I do.
Old 09-13-2008 | 10:35 PM
calvino's Avatar
i use baby powder, chalk dust, talcum powder, anything thats a powder, and will make it slide in easy [8D]
Old 09-13-2008 | 11:23 PM
ORIGINAL: RCCanuck
+1
Old 09-13-2008 | 11:47 PM
+2 on the baby powder or corn starch
