do i need this??
Old 11-16-2008, 04:54 PM
Default do i need this??
hello i have a smartech 1:10 4wd racing car and on mine when i started it one day the idling screw was wobbling around so i touched it and it fell out and now it wont go back in so is there a way to fix this and is it important and yeah the car does go along by it self it has been since i got it. thanks
Old 11-16-2008, 05:23 PM
Moderator
sheograth's Avatar
Default RE: do i need this??
You probably have to replace the carb, and yeah even if its tuned right at the moment it's good to have your idle adjustment working.
Old 11-16-2008, 06:39 PM
snowbl!nd's Avatar
The barrel may have to be in a particular position to allow the screw to thread in properly.
Old 11-16-2008, 07:48 PM
46u
46u's Avatar
ORIGINAL: snowbl!nd
+1 and in most RC carbs is what keeps the slide or the rotary valve from falling out.
Old 11-17-2008, 10:40 AM
ok thanks so is there away to stop it going off by its self because i have to jog beside it when it is running.
Old 11-17-2008, 11:09 AM
snowbl!nd's Avatar
Back out the idle adjustment screw to lower the idle speed.
Old 11-17-2008, 03:38 PM
when the screw was in and properly i turned the idle screw so it was down and it was still in it was going the same speed so why is it doing it?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
