Measuring engine temp w/multimeter temp probe
hey all,
Curious, does anyone here measure their engine temperature with a digital multimeter that has temperature measuring capabilities? I'm assuming you would contact the probe with the top of the cooling head, or even better, closer to the glow plug.
I use an infared temp gun but I would think that where you measure at would stay the same regardless of the device used to measure. I check at the GP or on the head as close to the level of the GP as I can.
Haven't used a temp gun for 6 years since I got into the hobby, never needed one. Maybe it could have come in handy in my TRX 2.5 days, but until I learned to tune I haven't ever needed one. Tuning my sound/smoke/performance is your friend. I guess the only reason I'd personally use a gauge is to measure temp during break in to make sure I'm over 210F.
Tom.
Tom.
ORIGINAL: rcnitrohead
Tom.
Tom.
The first 25 years I was in this hobby there was no such thing as a temp gun. But that does not mean they are not a useful tool.
Tom.
Tom.
I have one of those venom temp gauges with a probe that loops around the cooling head and displays the temp.
I also have a temp gun, as I heard a lot of people say how inaccurate those temp probes are. I have to say, after trial and error of what fin to wrap it around (eventually 2nd from the bottom) the temps have never been any more than 5 degrees different from my temp gun. So, at least for me, it's accurate, and it also has a peak hold function which is very usefull
The only accurate way I ever got a temp measurement using a multimeter probe (thermocouple, or thermistor type) was to use heat transfer paste betwen the surface to be measured and the probe. Messy.
My Feedback: (33)
Any temp detecting device will work if you use it properly . I use a temp gun that I use for work and is very trustworthy .
Yes , rcnitrohead people should tune to sound , smoke and performance . But not everyone does and even so it is nice to see what temps your engines are running at .
Oh sorry if I misread the OP's first message then. I poke my head in to try to save people from spending an extra $25-$40 they don't need. Its too simple to do without a temp gauge once you get the hang of it.
