i trashed my gearbox what kid should i get?
ok i have a tamiya grasshopper an the other day i destroyed the gearbox on it WHOOPS anyways when i get a new one i want something that has more speed then what comes stock any sugjestions? also i wanna get some racing tires wat kind should i get?
Moderator
RE: i trashed my gearbox what kid should i get?
There aren't really any transmission replacements that I know of for the grasshopper. You may be able to replace all the gears with metal ones though. As far as variable ratios go, you're probably going to be limited to pinion/spur combinations.
Banned
Their are no upgrade gear boxes for a grasshopper. You will have to purchase a new part. Make sure to put bearings in if you want more speed. More voltage with a stock motor will go faster 8.4 volts. Higher pinion gear or a slightly faster motor. Thats it.
