what is the difference?
Old 03-16-2010 | 07:16 PM
TRXRUSTLER's Avatar
My Feedback: (7)
Default what is the difference?
I was wondering what the difference is between an RC10T4 and the RC10T4 Factory Team? Will the parts interchange?
Thanks, Chris
Old 03-16-2010 | 10:19 PM
sheograth's Avatar
Moderator
Default RE: what is the difference?
The parts should interchange fine, I'm guessing the Factory Team version just comes with some hopped up stuff.
Old 03-16-2010 | 10:37 PM
Factory Team comes with better upgrades.
You can upgrade your non Factory Team car to Factory Team by purchasing Factory Team upgrades/parts. Or you can downgrade.
So the parts are interchangeable.
Old 03-17-2010 | 06:58 AM
As others have said, all the parts are interchangeable. The FT has a good amount of upgrades. Some are purely cosmetic, and some are technically better parts.
There is the ready to run version, a Team kit, and a Factory Team kit. The Team has a few upgrades over the RTR, and the Factory Team has a number of upgraded over the Team kit. I know most of the individual differences if you would like specifics.
Old 03-17-2010 | 10:58 AM
proanti1's Avatar
Associated factory team stuff is way overpriced... The aluminum screws suck, the turnbuckles break, and you dont even get aluminum shock caps. I dont think they have a team kit anymore. Buy a RTR, throw a set of lunsford Ti turnbuckles on, and be done with it. I picked up a GT factory team as one of my first trucks, I could have saved so much money with the team kit and 3rd party parts...
Old 03-17-2010 | 12:37 PM
TRXRUSTLER's Avatar
My Feedback: (7)
Thanks guys, I am getting a rc10t4 team kit in a trade, it has RPM ball cups and RPM a arms. Is there any other upgrades I should do before racing it?
Its this one: http://www.amainhobbies.com/product_...Team-Truck-Kit
Thanks, Chris
Old 03-17-2010 | 03:29 PM
proanti1's Avatar
ORIGINAL: TRXRUSTLER
Thanks, Chris
Other than decent electronics... Get a set of pinion gears (18-24) then a few spur gears (whatever comes stock... 80?). Aluminum servo mounts are a must, the stock AE ones strip really easy. Find some good tires too, I prefer panthers depending on track.
Old 03-17-2010 | 10:36 PM
TRXRUSTLER's Avatar
My Feedback: (7)
I am putting a VXL system in it, because its fairly new and it just laying around.
Old 03-18-2010 | 07:29 AM
MCSRacing's Avatar
vxl is a tight fit .. cut the mounting tabs off the esc and it'll fit barely .... factory team truck is much upgraded over the rtr and team truck .. the bet part of the FT is the shocks .. they make it worth the price difference ..
Old 03-18-2010 | 10:19 AM
TRXRUSTLER's Avatar
My Feedback: (7)
So the team truck has plastic body shocks and the FT has aluminium bodied shocks?
Old 03-18-2010 | 01:38 PM
The Team kit has teflon coated aluminum shocks. The FT version also has teflon coated aluminum shocks, but they are threaded for easier adjustment of the spring tension, and they have different shafts (better? I don't know, haha, but I believe they are different).
Old 03-18-2010 | 02:03 PM
TRXRUSTLER's Avatar
My Feedback: (7)
ok, thanks
Chris
