removing broken bolt on OS engine?
KY
My son removed the head from his OS 15 engine and somehow broke off one of the 4 capheads that attach it to the barrel. Any body got an idea how we can get the broken piece out of the barrel? also, what size are these bolts? Thxs
i don't know what size the bolts are, bur you can drill them out with a dremel or so. get a drill slightly smaller than the ones you got out of the engine in one piece.
this should help you out i hope.
Thats a very small screw to remove from the engine. Its possible but I doubt you would be able to remove it, especially if you used loc tite to fasten them in.
Another option is to drill out the screw, use a very small drill bit to do the job. Then go up one size and use a tap kit to tap a new hole for a new screw.
Dbow
Dbow
